G-Man, the source of the wear in the articles that AEHaas sites are the cylinders and rings, not the bearings. This has been missing from this discussion.
The other thing that he fails to mention is that the tests that were performed artificially heated or cooled the oil. The higher wear numbers occurred when the oil was kept at a lower temperature than it would have normally been in the block, while the temperature of the coolant was allowed to stabilize. There is not much generalization that you can do to the GM paper.
