From friends 22’ GMC Terrain. Almost 7,800 miles on HPL 0w20 and this filter. Same filter went back on. This one made November 2022.
You’re welcome. After my 3 Fram ultras that are older/wire backed I’m using my Donaldson member showed us. Those are heavy and high quality. Friend that owns this vehicle bought case for this vehicle and his other vehicles.beautiful filter with laser straight pleats. now if only fram could do it with the new style ultras. thank you sir for the C&P
Yes sir. I’d use these any dayAs always, stellar work, Adam! This filter was even worth the time it took to cut open!
the donaldson filter was also spectacular. just sad that you can’t run them for extended intervals.You’re welcome. After my 3 Fram ultras that are older/wire backed I’m using my Donaldson member showed us. Those are heavy and high quality. Friend that owns this vehicle bought case for this vehicle and his other vehicles.
Why not?the donaldson filter was also spectacular. just sad that you can’t run them for extended intervals.
Exactly. If I put one of those on; it’s on there for least 15kWhy not?
not worried about the nitrile ADBV?Exactly. If I put one of those on; it’s on there for least 15k
I’m am not sure.Nice looking filter. Wonder if they make these for Mazda's?
Nah, work has run CHAMP filters sometimes 10-15k without issue.not worried about the nitrile ADBV?
Think would cross to AC DELCO PF 64 that comes factory filter on these and Malibu’sThanks Stude. Is this ACDelco PF64 equivalent? Or the other one, I think it is UPF64.
Except this one is made in VietnamExcellent filter! Painted it blue to compete w/AC Delco filter.
