Post your latest small engine oil change
Couple years old MTD 395 SPO walk-behind mower.
Out: Elf Evolution SXR 5W-40
In: Same
Hint: car takes 4.5 litres, sold in 5 litre jugs. Easy to pull start, no noticable consumption, no smoke.
Customer machines:
Giant Vac leaf blower - 6.0HP Briggs Intek
Out: black water
In: Pennzoil SAE 30
Little Wonder SHO leaf blower - 9.0 Briggs Intek
Out: black water
In: Rotella T5 10w30
1980s Simpicity Regent tractor - 13.5hp Briggs OHV repower
Out: Rotella T 15w40
In: Rotella T 15w40
Craftsman 42" rider
Briggs 21 hp single
Out: Amoco 10/40, Napa 1348
In: mix Delo 400 30/formula shell 10/30, Fram filter
Craftsman 42" rider
21 hp single
Out: qs defy 10/40
In: mix Fred's 10/40/Havoline 5/20, Fram filter
Cub cadet commercial 42" rider
Kohler 21 hp vtwin
Out: unknown, Kohler filter
In: qshm 10/40, Motorcraft 910s
John Deere 42" rider
? 18 hp single
Out: unknown, jd filter
In: mix qs 5/30/qshm 10/40, Fram 3614
Champion 80CC 2000 watt inverter generator. 5 hour break in oil change.
Out - Champion 10W30 (made in China on the oil bottle)
In - Delo 400 15W40
Kohler Command 17.5 HP
out - Rotella 10W30
in - Rotella 10W30
In - Delo 400 15W40
out - Rotella 10W30
in - Rotella 10W30
I thought that little Champion oil bottle would be something nice to keep around to keep an exact oil change with the generator. Accidentally knocked it off behind the bench and the cap split and popped off dumping the Delo 15w30. Lesson learned.
Honda mower (GCV160)
Out: Valvoline MaxLife Full Synthetic 10w30
In: Havoline High Mileage Synthetic Blend 10w30
Honda inverter generator (GC190)
Out: Valvoline MaxLife Full Synthetic 5w30
Makita blower (24.5cc MM4)
First fill: Havoline High Mileage Synthetic Blend 10w30
Briggs & Stratton 700 Series Platinum Lawn Mower engine on a Craftsman lawn mower with a build date of March 2009. Annual oil change to start off the mowing season.
Out: No-name SAE30 oil. Not enough (my bad) and black and sticky
In: 18oz of Briggs & Stratton 4-Cycle motor oil
Murray 500E Series OHV, 21", 140cc (Briggs & Stratton) Push Lawnmower
Out: Pennzoil Conventional (PYB) SAE 30
In: Pennzoil Conventional (PYB) SAE 30
John Deere X300 Kawasaki 17 horse v-twin
Champion oil filter removed and Chevron HDEO drained.
Installed a Quakerstate oil filter and 2 quarts of Chevron HDEO 10w30 back in
2008 Karcher Pressure Washer 2500 psi with the Honda 5.5 hp engine.
OCI - 4 years (May 2014 to May 2018)
Out - Amsoil 4 stroke Small Engine Oil 10w30
In - Delo Synblend 400XLE 10w30
John Deere 930m 25.5 Kawasaki
Out: Amsoil Small Engine 30/10w30
In: Amsoil Small Engine 10w-40
Ferris FW-25 with Kawi
Honda HRX 217 (two)
In: Amsoil Small Engine 30/10w30
Originally Posted By: Snagglefoot
Changed oil on a Honda GCV 160. Since I was out of bacon lard I used 50% Lazer brand cheap a$$ 30 weight and 50% Rotella T-4 10-30. I had 13 oz mixed but seemed to take about 10 oz. You sure can’t rush the 30 weight concoction down the fill tube.
Just realized I measured the oil level by screwing in the dipstick on the fill tube then pulling it out and reading it. On a GCV 160 you are supposed to unscrew the dipstick, wipe the oil off then insert the dipstick WITHOUT screwing in the dipstick. It now indicated I was low. I had to add about 3 oz of oil to get it right and was back up to 13 oz. Doesn’t sound like much but 3oz is 23% of the capacity. All this is in the owners manual.
Changed the oil in my Dads B&S 17.5 single cylinder riding mower.
Used a Briggs filter and Rotella 30wt.
My Toro Timecutter is next. I almost have 5 hrs on it, the recommended break in oil change. The engine is a 24.5 Toro twin. Haven't decided what oil to run yet. Probably Delo of some flavor.
2006 Generac 16kw standby generator, GT-990 twin cylinder, 1.0 liter engine
OCI: two years, 19 running hours (it's rusting in place)
Out: QSUD 5w30, Baldwin B33
In: 1 quart Pennzoil Platinum 5w-20, .7 quart Rotella 15w40, Baldwin B33
Changed the Toro's oil today.
Toro 24.5 hp commercial v twin
Stens oil filter
Delo 400XLE 10w30 semisynth
I couldn't find the Delo SD 15w30 that O'Reillys and Napa is supposed to carry. I had 10 gallons of the 10w30 that I got on clearance for my truck.
