Post a photo of your oil on dipstick (with miles)
About 0.5-1 qt every 10K, depending on oil.
I had an '11 which I purchased new. I owned it for 14 years and it was THE best vehicle that I have ever owned. Throughout it's life I replaced a TIPM, front hub assembly, a fan clutch, and of course maintenance tune ups, fluids, brakes,etc, but it was extremely reliable and everything worked. The only reason why I sold it was because it was starting to get rocked and lower front door rust. Living in Michigan, I have witnessed the damage each additional winter does once things start rusting. I would have purchased another one, but at the time the 5.7l was no longer available, and I wasn't comfortable with the 3.0l long term. I know it is an impressive engine, but the 5.7 is proven. Everyone is aware of it's issues and there are few unknowns. Loved that truck :) I wish you many more happy miles.
2018 Honda CRV 1.5l
48200 mi on engine
1800 mi on oil - 5w30 Valvoline Restore and Protect
Seems to be right at the top of the full mark. It's starting to darken a bit too.
2003 Honda Civic 1.7l
188400 mi on engine
2400 mi on oil - Valvoline Restore and Protect 5w30
Hard to tell, but the oil level is that line just to the right of the shine about 2mm below the full mark. .5 qt was added about 900 miles ago when the oil level got halfway between the full and low marks.
Is there a story to the 1/3.5 ratio?
I was using the HPL EC30 to try and clean up if there was any junk to clean and that showed some bigger carbon junk from my motors. The EC30 is made/marketed/instructed to be a prep for full HPL oil use. The full formulated oil is supposed to be stronger with all the cleaning and other additive properties. Best used for extended intervals and at a higher price point. I’m not into extended drains currently. My backyard chemist (probably wrong) was to use a quart of the better fully formulated oil instead of EC30.
The 1/3.5 ratio was to add a full quart easy of HPL and the rest of what I needed with whatever I was using for vehicle oil capacity. If I had bigger motors/capacities it might have been 1/4.5 or more.
2014 Honda Accord EX-L, K24 2.4 liter “Earth Dreams engine, 130,500 miles,
Miles on oil: 3,688 miles, Valvoline Restore and Protect 5w30 w/ Fram Titanium 7317
(1st run of VRP, I am looking to change it out soon early, to do a second run and do it for the full 5k)
2006 Toyota Sequoia Limited, 4.7 liter 2UZ-FE, 217,500 miles
Miles on oil: 2k miles on Valvoline Restore and Protect 5w30 w/ Fram Titanium 3600
(1st run of VRP)
No consumption whatsoever (knock on wood) it’s been quiet and the dipstick shows a darker amber color. Interesting, to say the least.
'19 Pilot, VRP 5w30, 5162 miles on oil, 77714 on motor. Gained a little bit from fuel dilution as it was just at the full line when put in.
2010 Forte, VRP 5w30, 2357 miles on oil, 194,213 miles on motor, no makeup oil added.
'21 Tucson, VRP 5w30, 1882 miles on oil, 27,984 miles on vehicle. Had more highway trips and longer local drives. Didn't gain any from fuel dilution so far.
2003 Honda Civic EX 188700 mi
Valvoline R&P 5w30 2700 mi
1/2 qt added at 1500 mi
looks like in another week or two we will be back at the halfway point and I'll add another 1/2 quart. Oil will be changed in late October, at about 4000 mi on oil.
