this was right after a change, so it had not all flowed into the filterWhat is that in? Is it diesel? Why does it look like many qts between the low dot/hole and the cross hatch?
So how are these older GDI's passing emissions test at 80K with this much blow-by.
its not blow by, its soot from unburned fuel. with direct injection fuel droplets can make it into the cylinder and get burned before they evaporate, and since you cant get air mixed into a droplet like you can with a vapor it makes soot. this is also why diesels smoke sometimes, too much fuel and it's not vaporizedSo how are these older GDI's passing emissions test at 80K with this much blow-by.
Unburned fuel is even worse at emissions testing time.its not blow by, its soot from unburned fuel. with direct injection fuel droplets can make it into the cylinder and get burned before they evaporate, and since you cant get air mixed into a droplet like you can with a vapor it makes soot. this is also why diesels smoke sometimes, too much fuel and it's not vaporized
it's not unburned (like running rich) its partially burned, if that makes any sense. and because its a solid instead of a gas some machines don't measure itUnburned fuel is even worse at emissions testing time.
Just how many bleeding people are you coming across that you're seeing trends?Blood can change in viscosity though.. thinning from blood thinners or thicken a lot from very high blood glucose levels…
Just my observation but people on blood thinners I have noticed their blood did not have a normal regular red color to it. It was typically a little bit lighter vs say my blood which I don’t take warfarin.
1997 Mercedes C250 Turbodiesel. Oh crap it's black, already time to change it after only 1000 km?
Well its up to just over 4800 miles and getting dirtier. Not sure if I'll swap at 5k or just after. Depends on timing and weather.'08 CRV - 3070 on OCI, 235,250 on the motor. No makeup oil added. XG7317.
Oil is a 5w30 mix from almost 3 months ago. (1.5qts PP 5w30, 2.5 qts PP Euro L 5w30 and 1qt HPL PCMO 5w30).
