Originally Posted by 53' Stude
Originally Posted by supton
Legality or not, the rubber under the tread (between groove and carcass), can that be a different compound than the stuff that wears off? I'm wondering if a harder compound might be used as a layer between carcass and the area that is grooved, so as to stiffen up a tire. Or otherwise be used to mold the tires performance.
I don't think the rubber would be softer, but then again, could it be both harder (less compliant) yet quicker to wear off?
Asking for a friend. [Who might be a bit ducked in the head.] [I crack me up.]
Makes sense to me, dry weather tires don't need tread. Heck wet weather tires don't need tread either--as long as you go slow enough. Bicycle tires, at least road tires, do just fine with no tread whatsoever, even in the rain.
Go ahead and drive on them. I'll stay where I am and safe. Forget I even posted about this as some folks are plain nuts!
Where did I say I was going to do this??? FWIW I start tire shopping at 4/32's.
Geez.
Geez.
