Originally Posted By: Wilhelm_D
Originally Posted By: ZeeOSix
Maybe these guys who don't believe there's a problem with Purolators tearing media, and that it's perfectly OK to run an oil filter with tears in it might be plants from Purolator to try and make it look like a "non-issue". Good luck with that ... the guys with some common sense and logic who see the reported failures here know it's an issue that's not normal.
Apparently you don't understand, and don't want to understand, the difference between a failure - examples of which I provided - and a defect which does not appear to represent any significant threat to either the engine or the oil.
This anti-Purolator crusade reminds me of the anti-Mobil 1 crusade that overran BITOG a few years ago.
It's clearly a failure. It was manufactured without tears in the media, and the tears occurred during use ... hence, a failure.
Again ... this is NOT an "anti-Purolator crusade". Apparently you think that defects and failures are all nice and dandy in products. Like I said it doesn't matter what the brand name is on the side of the can, if it fails it fails, and it deserves to be scrutinized.
