quote:
Originally posted by BadBatsuMaru:
Anthony has a very well done test, and it makes perfect sense that the K&N filter would trap less dirt.
The only problem I see is that in every test, the amount of dirt on the second filter is directly proportional to the flow-rate of the first filter. Higher flow = more dirt. The obvious conclusion is that the higher flow filters trap less dirt, but there could be other reasons. Higher flow quite simply means that there is more air passing through the second filter, so of course it's going to get more dirt on it! The only way for the second filter to remain as clean with a high-flow primary filter would be if the filter's efficiency increased proportionally with airflow, which would be quite a feat. There's also another possibility. The engine pulls air through the intake. The air will take the path of least resistance. There may be small areas beyond the second filter where a little air is able to enter. When you stick a restrictive paper filter in the box, that will therefore cause more air to be drawn through any leaks beyond the second filter, causing the second filter to trap less dirt.
Of course, all this devil's advocate talk probably isn't necessary. If there are UOA's showing increased silicon with nothing changed except the filter, then there you have your answer.
One other thing you have to keep in mind, though, is that just about anything you do to get more power out of an engine puts more stress on the engine. You've got half the people on here who no doubt think it would be ridiculous to put a K&N filter on your car if there is a chance of it actually being worse for your engine than a Fram. That's understandable. At the same time, you have to understand that a cold air intake with a K&N filter sounds good, looks good, and gives you a tiny bit of power. Nobody's advocating a 100-shot NOS system here. You can, however, easily argue that a high-flow air filter gives a boost in performance and the extra wear is almost completely inconsequential over the lifetime of your engine.
