This is my third sample on my RX-8. Overall it appears that wear metals from break-in are trending down nicely.
This interval was a bit different from the previous two in that I took it for a 400 mile trip just before changing the oil. I did a double oil change last time so very little of the factory fill should remain at this point. Also, this sample was taken with a Vampire pump (excellent!).
Results are listed from most recent to oldest, and Blackstone did all the tests.
This was the last of my short interval changes. I plan to sample again 2000 miles into the next interval using the Vampire and depending on the results stretch it out to 4000 miles.
Viscosity continues to run on the low side due to the ongoing fuel dilution. This may improve as the engine continues to break in, but this time around, I re-filled with Castrol Syntec Blend 10W-30.code:
Oil Pennzoil Pennzoil Mazda
Grade 5W-20 5W-20 5W-20
Miles on Oil 2014 1967 2037
Miles on Car 6018 4004 2037
Time on Oil, days 77 97 102
Make-up Oil, qt 0.7 1.0 0.0
Oil Filter OEM OEM OEM
Air Filter OEM OEM OEM
Al 3 6 9
Cr 3 5 5
Fe 16 30 30
Cu 4 13 19
Pb 2 1 3
Sn 0 0 2
Mo 240 289 551
Ni 0 0 0
Mn 0 1 1
Ag 0 0 0
Ti 0 0 0
K 0 6 9
B 79 84 130
Si 7 21 49
Na 2 4 8
Ca 2110 1845 1750
Mg 4 5 4
P 768 641 745
Zn 937 718 817
Ba 0 0 1
SUS @210°F 48.5 46.9 48.7
Flashpoint,°F 355 310 335
Fuel, % 1.5 2.3 1.5
Antifreeze, % 0 0 0
Water, % 0 TR 0
Insolubles TR 0.4 0.2
