quote:
But as for finished product lines, let's see..Buckeye might be a good name for one...
quote:
Oil wells in Chanute Kansas once produced an oil so rich in alkanes and natural wax isomerates that the oil was simply filtered to make motor oil, and was naturally green in color (about 35 weight). So the Penn. myth continues, even though there were other oil fields producing much better quality oils. An oil well near Coffeyville Kansas (near the Oklahoma border) produced oil so rich in Kerosene that it only needed a low temp fractionization to produce consumer grade kerosene (coal oil), gasoline, and a light yellow-colored motor oil.
I had go really dig deep to find out which conventional oils use Pennsylvania base stocks. Pennzoil, Quaker state, Castrol GTX, Amolie, and Wolfs head. Most of the crude is refined in Ohio plants. Don't hold me to it, the information was gathered from various sources, some of which I considered hearsay but I believe the oils listed do use Pennsylvania based crude.
So, how relevant is the notion of "Pennsylvania Grade Crude" in an era dominated by hydrogen isomerized Group-II and Group-III base stocks?
Essentially, none.
I lived in that area all my life.I used to use Kendall GT 20W-50 in my turbo charged Saabs. I never had it analyzed, but once when I had head problems (the old 8 valve heads were notorious for developing cavitation and holes in the jackets surrounding the exhaust valves if the pressure in the cooling system wasn't up to snuff) and had the head removed, the valve train assembly was very clean. The virgin oil had a very beautiful green-gold color. If I could still find the stuff at a reasonable price, I'd consider using it in my '98 engine (Saab B234R). This is anecdotal, but I've been told by friends of people that work at the Saab plant in Sweden that they consider one of the better motor oils to use in their transaxles is a PA crude - Quaker State 10W-30.
