Originally Posted By: ZeeOSix
Originally Posted By: Hounds
Originally Posted By: fdcg27
How could a guy with zero experience waltz into the cockpit of a complex high performance turboprop airliner, start both up (this would have been the east part, since I'd bet that there are a couple of buttons labeled "start"), taxi out and then successfully take off, climb and then level out, much less fly some pretty wild aerobatics and then bring the flight to a conclusion at the place of his choice?
The same way you get to Carnegie Hall: Practice, practice, practice.
https://www.justflight.com/product/dash-8-q400-pilot-edition-fsx-download
I bet the FBI will be looking at his computer to see if this software (or similar) is on there. I'm betting this is how he knew enough to fly the plane. The other part of the puzzle was him being able to move the plane out of the hanger and turn it 180 on the tarmac, but that was part of his job at the airport already.
Anyone who's actually soloed even a simple piston single knows that while a desktop application can be very useful as a cockpit procedures training aid it shows you nothing at all about actually flying an airplane and this thing is a long way from a C172 in weight, complexity, performance and speeds for things like takeoff and climb.
Unless the FBI finds a full motion sim in the guy's basement, I don't think that his apparent skill in operating this aircraft can be explained without his having at least some experience in operating complex twin engine aircraft. That it was a turbine would have simplified things in that I'm pretty sure it would have had autostart and FADEC, so engine startup and management wouldn't have been an issue. Still, the guy operated the aircraft under control for about an hour and flew through some extreme maneuvers without failing the wings or the empennage, further indication of learned piloting skills.
The aircraft was apparently in a hangar (a hanger is what you have you shirts on) and he would have moved it out onto the ramp (not "tarmac") using a tug, easy enough had he done it before, although usually you'd have at least one wing walker to watch that the aircraft doesn't get run into anything, as you'd see during any pushback from a gate.
I guess what I'm trying to convey is that no desktop application could have brought this guy to the apparent level of proficiency he demonstrated in operating this big, fast turboprop twin. I actually can fly and have flown light singles all by myself for a number of rental hours and I'd not be at all confident of my ability to operate the aircraft in question even after many hours spent with a desktop application showing me where everything was located and how it worked. Bear in mind that this aircraft was also intended to be flown by a crew of two with the workload spread between the two fully qualified pilots up front, both of whom would be ATPs these days.
This whole event remains a mystery.
