Particle Count Database
twX
Canada
I've been building a dataset of particle counts (PCs) from used engine oil tests, with the intent of comparing how different models of oil filter perform. All of the data is from PCs that have been posted to this site over the past 20 years or so. They're all from gasoline engines with model years ranging from the late 80's to present day. To date, there are 75 particle counts included.
Certain test results were considered to be outliers and were excluded from the dataset. Most of these outliers had high particle counts combined with high wear metals on the UOA, often with high silicon or coolant contamination as well. One was excluded due to suspected filter clogging.
Only results for the third ISO code (particles >14 micron) are shown. The reason for this is that Blackstone changed their testing methods around 10 years ago. They used to use extrapolation for determining the counts of the smaller particles, instead of actually measuring them, which basically makes those particle counts meaningless. It's also impossible to compare the PCs that were measured using the two different methods, since the old method produced results that were 5 to 6 ISO codes lower for small particles. In the >14 um size, there is no obvious difference in results between the two methods, and they're assumed to be comparable.
Wherever possible, actual particle counts were used to calculate ISO codes to one decimal place, for better precision.
Table 1 shows the average particle count results by model of oil filter, as well as the standard deviation, and the number of test reports the average is based on. The averages for almost every filter include PCs from multiple different engines. Only tests done by Blackstone are included.
The relative ranking of the filters is more or less as you would expect, with known efficient filters like the Amsoil/Royal Purple greatly outperforming known low-efficiency filters like the Purolator BOSS and OEM Toyota. The standard deviations are small enough to conclude that many of the differences between filters are statistically significant.
It isn't obvious from the table, but the particle counts have a much more obvious correlation to the oil filter model than to any other factors I could identify. The model of engine doesn't seem to be too important. Oil or filter change intervals don't seem to matter much either, though it seems there are a couple of exceptions with long OCIs. Any factors aside from the oil filter that affect the particle counts should average out, at least for those filter models that have a large enough sample size.
Table 2 shows the particle counts for filters that I only have a single test result for. It's hard to draw strong conclusions about oil filter efficiency from this due to the limited data, but here it is.
If you'd like to help contribute to this dataset, please post links to any new particle count tests to this thread. I've scoured most of BITOG for any particle count tests posted here, but if you have any PCs that you suspect I've missed, or if you're aware of PCs posted to other forums, please post links to the original source here.
If you're going to get a particle count test done, having it done by Blackstone would be most useful for expanding this dataset, and you'll have a large dataset to compare your results to as well. WearCheck also seems to do a good job with particle count tests. I would avoid SpeeDiagnostix, since all four PCs I've seen from that lab have had the exact same ISO code for every particle size, and with particle counts much lower than what is typical from Blackstone, so I question their accuracy.
I'll call Blackstone and see if I can add a particle count to the oil sample I just sent off. It was a royal purple with 9,325 miles on it.
To add ... here's the ISO 4406 Code table which shows the doubling of the particle counts per mL for each increase in ISO code. Also shows the range across one ISO code is double the particle counts.
Eyeballing the data, I'd have a hard time seeing any statistical differences between the best and worst filters. They are all +/- 2 or 3 SD from the mean.
I called them, my last sample has been checked in, not tested. Added a particle count to it.
  • Like
Reactions: twX
I would have expected the OG Ultra to rate higher based on Ascent's ISO efficiency test results on the OG Ultra he tested, and Fram's ISO efficiency claim. Did you look at any newer Ultras without the leaf spring gasket and possible leaky leaf spring? How do you know all the Ultras in the PCs were OG versions?
The Royal Purple, Amsoil and the older PureOne I believe where also ISO rated 99% @20u. Wonder who was making the Mobil 1 filters in those UOA PCs? Oil filters have change so much over time that who knows what impact that had on the UOA PCs taken over the last 20 years.
What would be interesting is to see a series of UOA PCs on the same engine (with the same basic use conditions and OCIs) with different filters (or just try a very low vs very high efficiency filter), and have the PC done by a test lab that can actually accurately count all particle ranges down to 4u instead of using extrapolation. Can Blackstone now really accurately measure the whole range of particles in ISO 4406 down to 4u? Anyone verify this with them? Looking at the particles below the 14u point would better show which filters are strong performers and give an indication on how the efficiency drops off way down low.
I'd think if an accurate ISO 4406 measurement of all the particles down to 4u was done, that the OCI length impact would be seen more on less efficient filters because they will always be allowing more smaller particles through the media that they just can't catch regardless of how many passes through the media compared to a much higher efficiency filter. And there could also a stronger sloughing off factor due to dP increase involved with the lower efficiency filters in the smaller particulate range. In that case, the longer the OCI the more the "it can never be catch" particulate level should be. Higher efficiency filters are much better at catching and retaining debris, and should be better at keeping the oil cleaner as the OCI increases compared to lower eficiency filters.
There's a big difference between an ISO code of 12 and 16 in terms of the amount of particulate - 16 times more particulate. Reference the table in post 4 to see what the ISO code represents.
Ah, I skipped right over that. I was looking at the numbers like they were absolute counts.
Here's a visual representation of the difference between the Amsoil and OEM Toyota particle counts, based on the mean and standard deviations, and assuming normal distributions (and assuming I did this properly). I don't know if the confidence interval is >95% or whatever might be considered statistically significant, but it's high.
One newer FRAM Ultra with synthetic blend media was included in Table 2. I believe the others are all OG Ultras. Some were confirmed to be. Do you know when exactly the new filter design became available? All of the "OG Ultra" filters were installed between 2010 and late 2019.
4 of the 12 Mobil 1 filters are from 2018 or later. 8 of the 12 are from 2011 or older. The particle counts for the older filters are noticeably lower. Edit: The older Mobil 1 filters averaged ISO 13.0, versus ISO 14.5 for the newer filters.
What would be interesting is to see a series of UOA PCs on the same engine (with the same basic use conditions and OCIs) with different filters (or just try a very low vs very high efficiency filter), and have the PC done by a test lab that can actually accurately count all particle ranges down to 4u instead of using extrapolation. Can Blackstone now accurately measure the whole range of particles in ISO 4406 down to 4u? Looking at the particles below the 14u point would better show which filters are strong performers and give an indication on how the efficiency drops off way down low.
I do have some data that includes different filters tested on the same engine. I might make another chart to show some of those comparisons.
I don't have much faith in the 4u counts from Blackstone. Every single PC from the last 10 years from Blackstone comes in between ISO 22.5 and ISO 24.6 at 4u. I'd expect more variance than that. There's a lot more variance in the 6u counts.
I suspect that WearCheck might do more accurate measurements for smaller particles, but I'd like to see more reports from them.
Even if a filter is only 5% efficient at 4 to 6 micron, it should in theory still filter 99% of particles in that size range after around 100 passes through the filter (assuming no more particles are introduced). Particles below a certain size should continually increase, but I think that size would normally be <4u, even with a 40-micron oil filter.
The engine itself is also able to grind down particles in the 4 to 6u size range over time, and that would put an upper limit on how high the particle counts in that size range could get.
It might work that way if there was virtually no dP across the media - ie, a flow rate so slow through the media that the dP was very low. We saw from Ascent's ISO testing that the lower efficiency filters sloughed off way more debris as the dP increases. That's a known aspect of oil filters, and less efficient filters slough already captured debris worse than high efficiency filters. There was a thread a while ago showing real time data acquisition of dP pulsation testing and how the efficiency lose seen in real time corresponded with the dP spikes.
So a lower efficiency filter on an engine under constant levels of dP variation and pulsations due to changing viscosity and flow rate is going to be constantly sloughing off debris more than a higher efficiency filter would. Even if there was a constant level of particulate to start with (no particulate added with time), there will be a constant sloughing of some particles going on due to the level of dP and the efficiency of the media, which would increase the level of particulate in the oil that could essentially never be retained by the filter. At some point, the cleanliness of the oil would reach equilibrium after multiple passes depending on the dP level, and I would think the equilibrium would be a dirtier level with a lower efficiency filter vs a high efficiency filter. A large part of an oil filter's filtering performance is the debris sloughing factor under dP conditions.
While I'm not sure that are absolute values, I ran a statistical analysis and you're correct. There is a statistical difference. I know why I don't use my college degree. Lol
FYI, here's a good article by Machinery Lubrication explaining some of the changes that particle count standards have changed over the years. Looks like these changes were kicked off many years ago, so I'd expect any good lab to be using the current standards, but who knows for sure without getting details from said laboratories.
https://www.machinerylubrication.com/Read/12/iso-particle-count
I couldn't find this with a search. Do you happen to have a link?
The data for the AC Delco filter showed the "micron rating" shifting by around 5 microns, from 94% at 15 micron to 94% at 20 microns. Maybe that's enough to make up to a 1 ISO code difference in a particle count, but of course the ISO test doesn't involve any pulsation and the efficiency might drop a lot more in an engine. IMO, this is one of the weaknesses of the ISO 4548 standard. It would have been interesting to see this data for smaller particle sizes.
There are a some interesting particle count tests that involved testing the same oil filter at different mileages on the same engine. Some were done by @Patrick0525 with an OG Fram Ultra, with particle counts at 5k, 9.5k, and 14k miles without any oil or filter changes:
Efficiency drops the most at >6u and >14u. The particle counts increase the most between the first two intervals, and less afterwards, which is consistent with Ascent's testing.
A similar comparison was done with an Amsoil filter at 5k and 10k miles. The increase in the particle count by 10k miles amounted to less than an ISO code.
Another comparison was done with two Toyota OEM filters tested on the same engine. It's an older PC, so the particle size distribution isn't accurate, but the ISO Codes at <14 um were 14.5 at 1,550 miles, and 16.7 at 10,000 miles. It's a similar result to the OG Ultra test but of course we don't know how it compares for small or large particles.
It's hard to see any correlation between mileage and particle counts for the PCs in the rest of the dataset, but there aren't many tests with >6k miles.
The same user who posted the Toyota OEM filter comparison, @GeorgeCLS, posted an interesting comment regarding his own lab testing of oil filters under ISO test conditions versus variable flow conditions:
My comments are relative to the ISO 4548 multi pass test procedures and their relevance to automotive application. ISO 4548 is multi pass oil flow testbut the test uses a constant flow rate during the test. Unfortunately, no automotive/truck engine oil flows at a constant rate. It would seem to be "so what's the big deal?"
I have tested name brand industrial microglass filters which yielded a 3 micron beta 200 under ISO 4548 constant flow testing. Yes the same filter tested with the new variable flow rate test method yielded a 50 micron beta 200 rating. (!)
An incredible reduction took place in filtration efficiency when the filter was exposed to a more "real world" situation with varying oil flow rate.
Thus I have trouble accepting the published XBeta Ratios as absolute and even being relevant to automotive varying flow application..
Ideally, real world oil analysis results using particle counts would provide bottom line data that *would* be real and relative for comparison.. That also means lots of time/money and would take years to complete..
George Morrison, STLE CLS
I don't think that a filter's performance in real-world conditions with pulsating flow and dP can be simply boiled down to "higher efficiency = better particle retention".
It could be that the OG Ultra doesn't perform as well as it did in the ISO test because its performance is a lot worse in variable dP conditions, or beacause of some other aspect of operating in engine conditions that aren't replicated by the ISO test.
It wouldn't take much of a change in actual particle counts to toggle an ISO code up or down if it was already on the boarder line of an ISO code - it could literally take a very small change of more or less particles to move up or down one ISO code. This is one reason I like the raw particle counts and not ISO codes.
If any test did pulsation testing, it would clean back up after the pulsations stopped - ie, like suddenly revving an engine up to near redline while going through the gears getting on the highway, then coming back down and cruising at a constant RPM for awhile. If the pulsations were continuous like in some kind of hydraulic system then that would be a different outcome. I'll look for the thread I mentioned and post the link later.
Particle counters used in ISO 4548-12 can go down to 5u if the right one is used (if that's what you meant). This is out of the ISO 4548-12 procedure. Ascent's ISO test only went down to 15u, and it would have been nice to see it go down to 5u to see if that OG Ultra he tested made the 80% @5u that it was said to be good for.
Doing it on the same engine will give the best data as seen in the table. Keep in mind that the >4u data point includes all particles >4u, so it also includes all the particles at >6u through >38u, and the particle count difference between ISO codes at the >4u code level is pretty large. Each ISO code is double the particles, so an ISO code change for >4u from ISO code 22 to 23, the particle range is 20,000 to 40,000 difference in particles, while an ISO code change for >38u from ISO code 6 to 7, the particle range is 0.34 to 0.64 difference in particles. So as the ISO code goes down, it becomes more sensitive to changes in particle count in terms of moving the ISO code due to an increase or decrease in particle counts. This is another reason why I don't really like using ISO codes, because it kind of masks the finer details. Looking at the raw particle counts of an ISO 4406 particle count test at >4u through >38u is a better way to see what's going on.
The best way to compare the oil filter's efficiency on oil cleaniness in real world use would be to use the same engine with the same basic use conditons and OCI, and use the same test lab that is verififed to use an accurate and repeatable particle count test method that accually measures down to the 4u level.
"I don't think that a filter's performance in real-world conditions with pulsating flow and dP can be simply boiled down to "higher efficiency = better particle retention".
The ISO 4548-12 test does take into consideration the dP increasing and the resulting impact on the efficiency, so it does give an indication of how much the filter will slough debris with increased dP. Of course you have to look at the raw PC data to determine how much efficiency the filter loses at each measured particle size against the change in dP throughout the test. Even though the dP is increasing at a steady rate and not pulsating, it still shows that filters that rate higher in efficiency will also have less debris sloughing due to increased dP. So my thought would be that those filters should also handle dP pulsations better than a less efficient filter that loses a lot of efficiency just from a steadily increasing dP. And as mentioned before, when debris is sloughed off due to some dP pulsations, a more efficient filter should clean it up faster than a less efficient filter.
Here's the thread ... it was about how a super fine metal mess filter didn't suffer from dP debris sloughing like regular filters do. The videos show the real time test monitoring of the situation.
Another reference to debris sloughing as dP increases wrt Ascent's ISO testing.
I realize this. When I say up to one ISO code, I mean a full ISO code, or a doubling of particles.
Yeah, it would be better if the codes only represented the particles up to the size for the next code number. The counts for >4u and >14u can both be affected a lot by this since they are close to the next size up, whereas >6u and >21u aren't usually affected much.
ISO tests do show a reduction in efficiency with increasing dirt loading, but it shouldn't be assumed that the drop in efficiency is directly caused by the increase in dP.
Look at the Ascent test with the AC Delco filter. At 15 um, the largest drop in efficiency is between the first two intervals. The beta ratio drops by 30%, even though the dP increases by less than 5%. That small increase in dP shouldn't have much of an effect on the efficiency. It's the dirt loading itself that's causing it. Between the last two intervals in the test, the beta ratio only drops by 15%, despite the dP increasing by 36%.
The drop in efficiency has a correlation to dP, because dirt loading has an effect on both of these, but the increasing dP isn't the direct cause of most of that efficiency loss.
That's pretty interesting. It does make me wonder if there can be big differences in how different types of media perform with regards to particle shedding with variable flow.
Just based on the particle count data I have, I have a suspicion that the OG Ultra might perform worse in this regard versus some other filters like the Amsoil/RP, but I think both filters use similar synthetic microfiber media, so, I don't know.
If you want to manually do the work using the raw particle count data, you can determine how many particles are in each range, As shown in the example below.
It helps to plot the loss of efficiency over the test period, like Davejam did here - it happens to be for the AC Delco data in the table above. There's no doubt that the drop in efficiency has a strong correlation to the dP across the media. If a filter was loaded to a certain level, and the debris loading was stopped and dP pulsations were introduced to see how it shed debris and subsequently cleaned up, then that would be similar to the pulsation tests shown in the videos in post 17. Without seeing a test like that, I'd have to believe that a filter that showed much less debris shedding as the dP increases in the ISO 4548-12 test would also do better in a pulsation test like that.
Another interesting observation in the link below from the Ascent test thread. The change in dP and the corresponding drop-off in efficiency aren't both linear, and this can be seen by plotting the data.
As mentioned earlier, my theory is if a filter doesn't shed/slough off debris very much in the ISO 4548-12 test as the dP increases, then it should also resist shedding with dP pulses and spikes compared to a filter that tests much less efficient in the ISO test. A filter that sheds a lot of debris as the dP increases will result in a poor ISO 4548-12 efficiency. That's a big reason filters like the Wix XP and Purolator have low ISO efficiency. A very high efficiency like the 3 top filters that Ascent tested can't have an ISO efficiency that high unless they are very low shedders as the dP increases.
