.....quote:
Only one unique oil in the world actually brings engine friction nearly to zero. That truly high performance oil comes from a small company in Santa Fe Springs, California called Torco International. We recommend their 20W-50, 15-W40 and/or their straight 40-weight MPZ oils and additives. We get it in 5-gallon pails. We use their motorcycle and diesel oils for everything. You can expect a 15 to 30-percent boost in mileage with all piston engines in cars, trucks, motorcycles, aircraft and heavy equipment. Plus greatly improved life of the parts. NEVER use 5w30 or 5W-20 oil because it is closer to a grinding compound than a lubricant. We always add Torco MPZ Magnetic Additive and a bottle of EAL Engine Assembly Lube every oil change
Maybe that's true - but he is talking full flow and we hardly see this with bypass!!quote:
Only a really good filter can turn black dirty oil to a light brown.
That is PURE bovine scat marks!quote:
What kind of mileage increase will acetone give my car? Normally from 15% to 35% depending on your driving habits and how many of our mileage suggestions you have taken. We know an aeronautical engineer in San Jose whose test car went from a baseline of 19.3 MPG to 27. He certified this with his ScanGauge. That is a genuine boost of 27%.
I think that paper was an excellent read. It also went into good detail about 20wts and engine wear. A must read!!!quote:
Originally posted by Curious Kid:
I thought this was an interesting read concerning lube design vs. engine efficiency -
www.iantaylor.org.uk/papers/IMechEFE2000.pdf
enjoy...sorry if someone else posted this before.
Don't worry, Mola. Evolution and global warming are also being put in the category of religious belief systems -- even by some people who consider themselves scientists.quote:
Everyone has an opinion. Whether or not it is based on fact is anyone's guess.
And i think methanol and ethanol has been maligned in the press.
