onramp emissions testing in CA
CA
I've heard about these onramp testing stations for several years, but today was the first time I saw one in person.
At the end of an uphill onramp CARB-SCAQMD set up a choke point tester. People who got on the freeway had to pass through the sensors, get their tailpipe emissions tested, and I imagine their picture and license plate recorded.
Colorado has a webpage showing the equipment and how it's used:
http://aircarecolorado.com/rapidscreen/how-i/
As a vehicle passes by, the roadside testing equipment is able to analyze the vehicle’s exhaust in less than a second. Here’s how RapidScreen works:
The vehicle first passes through (3) speed and acceleration detectors, while an (5) image of the license plate is recorded for identification.
The vehicle then passes through the infrared and ultraviolet beams of the (2) emissions analyzer. A laser light source directs the beams across the road, where they are bounced off (1) mirrors and directed back to a detector module. As the light beams are broken by the vehicle’s exhaust plume, the detector module measures the levels of carbon monoxide, carbon dioxide, hydrocarbons and oxides of nitrogen in the plume. (4)The emissions readings are matched to the license plate and an official test record is created.
To ensure accurate, uncontaminated readings, RapidScreen testing vans do not operate during rain, snow, high winds or other adverse weather conditions. RapidScreen also holds to stricter emissions limits than those of a standard tailpipe emissions inspection.
That sounds like it's forcing people to get a mandatory emissions test done. I wonder what happens if they fail a car that's not due for another few months yet. Does the owner have until the original tailpipe sniff test expires, or do they suddenly have a two-week window to get the car fixed and re-tested? And, how can it distinguish between the exhaust of your car compared to the clunker that just wheezed its way onto the freeway? Getting closely packed cars to go by seems like it would be an issue.
While cleaner air is good, this seems like it's rife for abuse. Even more so than the tailpipe sniff test or the OBDII emissions test.
If you live in a state with mandatory emissions testing, I dont see how this is any different or worse than the inspection station. True, it may catch someone prior to the due date, but is that truly a bad thing?
I suspect that there are too many cars passing through these systems for them to be easily abused. Of course we can always create fantasy-land scenarios where someone is angry at their ex, coworker, etc. and fraudulently enters their license plate in place of the one on the smoking 78 Cordoba 440 going through the tester. But again, the reality is that this is likely all automated, no different than google transcribing house numbers, facebook recognizing faces, or EZ-Pass sending tickets.
Its all jack booted Nazism.
If you're a criminal illegally here from another country, I guess youll need to drive a clean car. But not much else to worry about.
I see those rigs set up pretty regularly in Los Angeles and Orange Counties.
Do my best to drive past them at WOT for 'honest' sampling. Never had any issues with our draconian regulatory agencies.
Originally Posted By: oldhp
I'd turn off the engine before I went through. That ought to confuse them.
^ this. With a stick shift it may be easy. The problem is with that choke point. If you have to accelerate through it because of the traffic it causes it may be more difficult... except for a Prius
Missouri had this 10 or so years ago. I don't think they take you off the road. It was a means of getting an earlier pass. If you passed the rapid screen, no need to go to a testing station when due. If you didn't, you would test at your scheduled time.
A few years ago, there was a guy on another forum that was flagged as a gross polluter because he had just recently started his truck up when he drove by the tester, and the catalytic converter hadn't warmed up yet.
Originally Posted By: Jetronic
how do they test diesels?
So far the diesel test consists of a visual inspection, check for codes present, and a smoke check. Funny because I have seen 6.0s with no EGR cooler and no EGR valve pass the visual because the smog tech had no idea what they were looking for.
