Oil turns reddish?
California
Just dumped my last fill of NextGen Maxlife from my '01 GMC Savana 1500. I've been checking the oil level every time I get gas, and while it didn't use any significant oil during the 3100 mi. OCI, it did seem to take on a reddish cast. Not red like ATF, just more red than the golden-brown I'm used to.
Does it mean anything?
Some oils change color.
I use Valvoline Maxlife in a 2000 Grand Am 4 cylinder, and about 750 miles in, it turns a bright yellow.
I was just noticing the color of mobil one HM, it almost instantly turned a bright urine yellow in a few different engines I am running it in.
Yeah, its very light to begin with so you can see it. Its mixing with the small amount of old oil remaining in the engine. I see that too.
I just drained my 3rd OCI of NextGen. It definitely had a red cast to it... I'm glad that I am not the only one who it's happening to...
I just poured some Rotella 15w40 from a 4qt jug to a 1qt container to top off with.
It was so much darker than the 10w40 I was using before that I thought I grabbed a bottle filled with used oil at first.
Turns out that the 15w40 is just a lot darker than I am used to.
I've also seen Green German Castrol and bright green Maxlife soon after it is put into engines.
Interesting stuff.
Maxlife often gets a glow to it that is entertaining. All the HDEO's I've used have been significantly darker than PCMO's, higher TBN's, more calcium etc.
Yeah it is intoxicating.
If I recall Pennzoil Ultra briefly took on a slight strawberry tinge that lasted a few weeks early in the OCI, like someone added bit of ATF to the sump. Found it odd.
I literally just dumped the plain Valvoline Next-Gen 5W-20 out of the Town Car, and I definitely noticed it was red where the stream got thin and the light showed through.
I had this happen one time on a 135K Honda Accord. No ATF loss, no other symptoms - very strange.
It was GF-4 Syn-Power 5w30 BTW, which was what I normally used.
Funny you mention this, I recently had the oil changed in my 94 Accord 2.2L non v tec at 129k miles and I noticed this as well. It is not lighter red but it definitely has a reddish cast to it.
I don't know what oil was installed since the dealer did the change, but I checked the ATF and no loss was noticed.
I tend to think it is some varnish as well, perhaps the newest SN formulas do a better job at cleaning, I'm sure the previous oil was SM formula.
Originally Posted By: Coprolite
Originally Posted By: TC
Oil turning red = Measles.
It's just that time of month. Give it a few days and it will go away.
Ha Ha HA !!!!
