Getting ready for my first OC on our 2011 Equinox and trying to decide on an oil filter. I like the Purolator PureOne and the Fram Tough Guard filter because they're 99% efficient. Does anyone know the efficiency of the OE AC Delco filter?
i would not run a fram!!
you can never go wrong with a purolator, mobil, or bosch.
the ac delco is hit or miss depending on the part number, just make sure its not an e-core if your using a spin-on filter
PureONE is advertized as 99.9% multipass efficiency at 20 microns for their sample PL30001 filter. And it appears to use the same media as almost all their others ones. (But some of the boxes say 99.9% MP at 40 microns particle size.)
The Fram TG is 99% efficient at some unspecified particle size greater than 20 microns. I don't remember if that number is multipass, or single pass efficiency. But in my opinion it doesn't matter anyway because we don't know for sure the particle size range tested for the 99% rating.
AC Delco website says, "•98% single-pass filtering efficiency at 25 to 30 microns for excellent filtering capabilities"
So that would probably translate into approximately 96% at that particle size range for a multi-pass test.
Pure One is a good choice, Wix/Napa Gold is a good choice, Fram EXTENDED Guard is a good choice (put Extended in caps as a point of emphasis). As far as A/C Delco, I can't really tell you much about that, but for my application, (2.2L '98 Chevy Cavalier) I used P1 for pretty much the majority of the 331,000 miles that's on it and it still runs very smooth 'til this very day.
I would rate WIX/NAPA Gold/CarQuest blue, Purolator PureONE or Classic, Bosch Distance Plus or regular Premium, or probably K&N or Mobil 1 filters all good, and Fram XG too. Not in any particular order here. Also I like the Baldwin Hastings types.
The only filters I don't usually run myself that I can think of are the lower end Frams (usually...but I have one on the VW now) and the Ecore designed ones.
Since that is a cartridge and not a spin most of the quality issues of a spin on is moot point. If it were my car I would use a TG, or a P1, Bosch, anything but low end. Post how the oil change goes as I am looking at purchaseing an equinox and am very curious. Thanks
Originally Posted By: Radman Since that is a cartridge and not a spin most of the quality issues of a spin on is moot point. If it were my car I would use a TG, or a P1, Bosch, anything but low end. Post how the oil change goes as I am looking at purchaseing an equinox and am very curious. Thanks
it depends.. the 4 cyl is a cartridge but the 6 is a spin on.
i guess we need to know which one it is
