Oil Consumption Check-in!
2011 nissan xterra 210000 miles - no consumption
5000 mile oil and filter changes with whatever is on sale.
Can we go back in time? My parent's 84 Caravan 2.2 1 qt every 125 miles. If there wasn't a crosswind it made a blue column down the road.
My Chev Trailblazer seems to drink half a litre in 20 - 24,000km when running PPPP 5w30. I don't recall having to add any when running Castrol or Quaker State. 245,000km.
My 3500 doesnt drink any during the 24k index. 82k.
Now my C1500 loses about 1 litre in the last 7k km. 379k.
Originally Posted by 28oz
2004 Nissan Quest VQ35DE 192,000 - maybe 1/4 after long highway run, but not always perceptible on dipstick.
1990 Nissan 300ZX VG30DE 110,000 - no consumption
2005 Ford Taurus OHV Vulcan 202,000 - no consumption
2003 Ford Excursion 7.3 PSD 223,000 - maybe 1/2 quart after towing 30' travel trailer.
*UPDATE* Just ran the Quest from SLC area to Phoenix and back. Zero consumption on the M1 EP 10W-30.
girlfriends oil thirsty 2013 malibu 2.5 using a qt on a thou at 62 thou is gone. iu used from new + got progressively worse!!! replaced by a preowned kia optima 2.4 that uses NONE, NO MORE GM JUNK!!!
That's what you get for using that fake synthetic...
Replaced by an engine also known to use lots of oil as it ages. Next up: no more Hyundai/Kia junk! Lol
2015 Jeep Cherokee, 3.2 Pentastar with 68,000 miles, 5w20 Valvoline Synthetic HM for almost all of those miles at 5k OCI's - no noticeable consumption.
Just sold: 2004 Dodge 1500 SLT, 5.7 with 100,500 miles, 5K OCI's with Super Tech 5w30 for about the first 50,000 and Super Tech HM 5w30 the rest of those miles - no noticeable consumption.
2010 GMC 1500, 5.3L, 4x4, 5W30 syn-blend, and a little aggressive driver... I would say I burn about 1qt @ 4K'ish. I just don't count, I just check the dipstick and level it out whenever I come to think of it. As for this truck, the REASON for the oil consumption is I have that (I don't know what those are called) 8cyl-to-4cyl thing. I know it can be turned off (disabled), but I just leave it alone. Just recently, I was losing oil pressure, so the mechanic took the oil pan off and replaced the o-ring (said it's common problem for chevys, hot/cold cause it to shrink). There was medium oil deposits (not too bad since I often change oil at 30% life left), so all that was cleaned out. Oh, 130K mileage as of now.
LOL that's what I was thinking...
My daughter's 2004 jeep liberty uses a qt every 500 miles. Changed pcv etc. Suspect valve stem seals.
Use mag1 high mileage 5w30
1987 F150, 4.9 inline 6 , 101k miles oil level is down 1/4 quart after 4500 miles so far. 2003 Grand Marquis 38k miles, no consumption at 5k miles.
2002 Ford Ranger 3.0L 75k miles
Castrol Edge HM 5w30-half a quart every 5-6k miles.
2013 Honda Civic LX 1.8L 189k- Mobil 1/Valvoline HM 0w20- none measurable if at all.
1995 Corvette LT1, 78k miles, no noticeable oil consumption.
2006 Tacoma 2.7, 160k miles, no noticeable oil consumption.
2001 Tahoe 177k, 5w30 blend.
Dipstick is down 1/2 quart on a 5 k change. I do have a weep in the rear main seal, which I threw a bottle of Blue Devil in. Might try a 2nd brand, as I'll be changing in about 3 weeks.
97 Integra, 267k, Mobil2 drained out from IS250 (10w30 + 5w20) and Prius V (0w20 + 5w20) once a year change + top off 1 qt every 2 months, it consumes about 1 qt every 1k or so. I change the filter every 3 months. It is on borrowed time and it doesn't owe me anything.
At this point I feel like you may owe it something.
1995 Ford Escort, 260K miles. Leaks one quart in around 900-1000 miles. I think it's an oil pan leak. Probably not worth fixing unless I have to remove the catalytic converter for something else, because oil is cheap. This is only disappointing because I recently replaced the head gasket, and in the process also fixed an oil leak on the valve cover, and I also replaced the oil pressure sending unit which was leaking oil. While the parts if the engine affected by those two oil leaks remains clean, there is still a lot of oil over the rest, and it didn't seem to reduce my oil loss in a measurable way.
5w30 high mileage regular (not synthetic). I don't care about the brand.
2001 Volvo V70 XC - 251K miles. Added 1 quart of M1 5w30 EP at 4200 miles.
This was a no makeup oil vehicle up to about 200K, but it's gone up dramatically since then. Not sure where it is going. It's not on the driveway, and the tail end isn't black or oily either.
2015 Chevy Sonic 1.8l - No oil added on a 4500 - 5000 mile OCI - Synthetic - ~ 70,000 miles on the odometer
2006 Buick Lacrosse 3.8i - No oil added on a 3000 mile OCI - Dino oil - ~ 50,000 miles on the odometer
