As I posted already, I just changed my oil the other day in my BMW. I removed Liqui Moly 5W-40 and replaced it with GC 0W-30. The one thing I noticed was the car seems to have a little rougher idle (occasional vibration) and a little more hesitation on light acceleration. Under load and higher revs, the engine seems to run smoother than before.
The engine is not showing any codes and there are no warning lights. I over-checked everything multiple times (drain plug secure, oil cap on, oil filter cap tight, no leaks, etc.). Oil sensor shows oil level is at max and okay.
Has anyone else experienced this when changing from a -40 weight to a -30 weight oil? My car only has around 5200 miles on it. Maybe I'm just being paranoid. Any feedback would be appreciated.
