Originally Posted By: Ben99GT
Originally Posted By: 1999nick
A look at an owner's manual from a vehicle I owned back in the 80's, a Pontiac Bonneville, show's recommendations for almost every weight of oil then manufactured, from straight 10 weight to 20W50, and everything in between. Temperature limitations applied. 20W50 was good from 20 degrees on up. 10W30 and 10W40 was good from 0 degrees on up. Straight 10 weight was good up to 60 degrees. Straight 30 weight was good above 40 degrees. The preferred viscosity was 10W30.
I really wish they still did this.
If you can get access to an FSM,it`ll have all of the usable oil weights per Toyota,and not the EPA/CAFE/government.
