Oil Additives for Lubrication vs Sludge
Carlostrece
$100 Site Donor 2025
PNW
I have heard that having more good additives for lubrication can result in increased sludge. I have heard that said of oils that have more ZDDP and/or more moly. Do you think this is true or just an incorrect urban legend?
Valvoline Extreme Protection Full Syn is an example of an oil with excellent additives for improved lubrication. Likewise with NAPA Full Syn (which I think is the same oil in a NAPA bottle). The increased level of additives (including moly) is known to improve lubrication, but does it also increase sludge or deposits?
With that in mind, what (if any) are the downsides of having high levels of additives?
I'm aware of cat issues with increased ZDDP. Does that also apply to increased levels of moly? How about sparkplug and valve cleanliness for port injection engines?
Valvoline Extreme Protection Full Syn is an example of an oil with excellent additives for improved lubrication. Likewise with NAPA Full Syn (which I think is the same oil in a NAPA bottle). The increased level of additives (including moly) is known to improve lubrication, but does it also increase sludge?
Does that
Source?
Various videos online, maybe including Lake Speed, though I don't recall for sure if he said it. I may also have read it a time or two at BITOG in the past.
My questions about this topic have been building up for months, but this is the first time I ever expressed those questions.
BTW - you replied before I edited my OP to contain all my questions on the topic. So you might want to give the OP a second read. Thanks 👍
Please research some of these voices okay? So far it’s a lot of nothing. It’s the phosphorus in the ZDDP which can poison the catalyst, therefore a molybdenum compound will not unless it contains phosphorus. And, this only happens when a relatively large amount gets there - like burning a quart in 500 miles or less.
I am researching the topic by posting this thread. Thanks for explaining about phosphorus and the cat. How does increased ZDDP and/or moly affect sludge and/or deposits in a port injection engine?
Still curious. Never heard of that.
ZDDP has a secondary role as an anti-oxidant. If anything, it helps prevent sludge. Likewise, MoDTC is also an anti-oxidant.
If you have a healthy engine, the amount of phosphorus is largely irrelevant to emissions system damage. An oil with 600 ppm P consumed 1 qt / 1k miles is putting the same amount of phosphorus in the cat(s) as an oil with 1200 ppm P consumed at 1 qt / 2k miles. I personally believe if you're burning enough of a 1200 ppm P oil to damage the cats, you already have bigger problems to worry about.
I’ve read about too much molybdenum could be a problem but what’s blended into an additive pack wouldn’t be a concern. I would steer clear of additives motor oil alone is good enough these days.
So, what are these additives? How do oil additives cause sludge? Where did you “read” this?
What credibility can you bring to this statement.
What is a good additive vs a more good additive?
@Carlostrece See this link for what defines sludge:
Molybdenum will poison the catalyst as well?
I asked about sludge, deposits, and cat. Those are 3 separate questions/issues. He didn't say which of the 3 he was referring to. I didn't automatically assume he meant the cat. Why did you assume he meant the cat?
The OP stated that “more good additives “ cause sludge….
No, I did not. You misquoted me and you misunderstood the OP context and intent.
I stated that I've heard that more (of some) additives can cause more sludge. I did not state that it's true or a fact.
I then asked questions about it.
I said in OP that ZDDP and/or moly are the additives I was asking about.
I don't know if they do. I didn't state that they do. I asked if they do.
Do you understand the difference between a question and a statement? The purpose of the OP was to ask questions.
I don't know what you're talking about. Neither do you. Please reread the OP and comprehend that I was asking, not telling or stating.
You are the most aggressive newbie I've ever seen with all of 33 posts under your belt. 🙄
