Originally Posted By: Cujet
After years of playing with dirt bike suspension, the key element is not oil viscosity. Yes, years ago, when forks and shocks had calibrated orifices, the viscosity mattered greatly.
But, today, with spring shim stacks, performance is dictated more by the shims involved. (with the disclaimer that the orifice size is sufficient) This provides consistent performance over a wide range of conditions and temperatures. Including compensating very well for internal wear.
Not long ago, I put 90W-140 gear oil into a shock, in an attempt to stiffen it up, as a "last ditch" effort. Not surprising that it made little difference. It worked well enough, and the rider finished the race with the same "underdamped" complaint.
I had Jeremy Wilkey send me a piston and shim "setup" for my Husqvarna 360 Showa shock. After a short discussion, he admitted that he has used Mobil 1 ATF in these shocks with good results. So I did. And it worked perfectly.
Im still on damping rods...
Oil Vis matters quite alot more to me (im a poor b*stard )
FML.
If i had the cash, i would just buy a new bike and run down to the ohlins center and have it serviced...
