My first time disassembling a PureOne PL14476 old style (blue can) for my 05 Corolla today. Everything seems fine, except for the relief valve.
The relief valve is not the spring loaded type you see in the WIX and Amsoil filters. Where it's an actual spring holding a small relief valve closed.
I don't even know how to describe the spring type the PureOne uses but lets just call it the Purolator spring. As this style spring is used in all Purolator filters and clones like the AAP and Bosch filters. I am too lazy to take any pictures but this is exactly what my PL14476 looks like:
I wanted to test the condition of the relief valve to see if it would actually open or depress with some force. I had to push down on center of the cap attached to the Purolator spring so hard that it eventually opened. And the Purolator spring was deformed and relief valve stayed open.
My first thought was... did this relief valve actually open when required to by cold winter starts or at high speeds where there is more pressure in the can? Second thought was... how come I have to apply so much pressure on the valve to get it to even budge that it broke the spring and left the pressure relief valve open.
I would like to hear what you think and your experience. As I'm sure some of you have the same Purolator spring in your oil filters.
