I'll try and find a better reference ..but this has been reported on this site by more than a few members and was in a presentation at the Amsoil regional meeting with the orientation for Amsoil PI. Before that, I didn't know what the heck the "would be piston slap that wasn't piston slap" people were talking about.
A condition known as Combustion Chamber Deposit Interference (CCDI) can also occur when the carbon deposits are so thick the deposits on the piston and head make physical contact. This area, known as the Squish Area (piston to top of chamber), has a clearance that is about as thick as a paper clip. This can cause a loud, metallic banging sound when a cold engine is first started.
The deposits are soft and will gradually flake off. But the flakes may lodge between the valves and seats causing a loss of compression, misfiring and rough running when the engine is cold (a condition called Combustion Chamber Deposit Flaking or CCDF).
..but I guess this is impossible
http://www.aa1car.com/library/bad_gas2.htm
Here's a more valid source that you may respect
Combustion chamber deposit interference (CCDI) and combustion chamber deposit flaking (CCDF) are two other problems which sometimes occur in certain modern engine designs. CCDI is the result of physical contact between deposits on the piston top and cylinder head and is manifested as a loud, metallic banging sound when the engine is cold. CCDI is limited to the engines that have been designed primarily to reduce emissions, with minimal clearance—one millimeter or less—between some areas of the piston top and the cylinder head (squish areas) when the piston is at top dead center. Combustion chamber deposit flaking causes low-compression pressures to result due to improper sealing of the valves. This problem occurs when pieces of CCD flake off and end up lodged between the valve face and the valve seat. Typical symptoms of CCDF are difficulty in starting and rough running when cold.
Texaco
and how about those clowns at SAE.org?? Man I really bought into the whole scam
Abstract:
Recently, an audible clattering noise has been noticed in some vehicles during cold engine starts, mainly in the U.S. The clattering is referred to by various names, such as "carbon knock," "carbon rap," "mechanical knock" and "combustion chamber deposit interference (CCDI)." CCDI is believed to be caused by the deposit formation in the combustion chamber. In the research described here, CCDI was successfully reproduced in a 2.5-liter multipoint injection engine with a polyolefin amine gasoline additive. It was determined that the CCDI was caused by mechanical contact between the piston top and the cylinder head deposits. The vibration due to CCDI originated mainly at the thrust side of the piston right after top-dead-center on compression stroke and was characterized by a high frequency response.
Combustion chamber deposit (CCD) formation depends on many factors, including gasoline additives. It was confirmed that there is a close relationship between the ability of gasoline additives to decompose and their effect on CCD. Various analytical techniques were also utilized to characterize CCD.
http://www.sae.org/technical/papers/950741
