start by removing the thermostat, replace housing and hoses, then disconnect the upper hose and backflush with a garden hose until it is clear water coming out---water will be coming out of the upper rad hose while you run it into the upper hose outlet. then drain, replace t-stat, then refill, bleed air. do this with the heater temp knob to the hottest position..... hopefully that will unclog a plugged heater core..... if that doesn't work, check the heater temp control...either the valve to the core isn't working or the cable, servo, isn't operning the valve or duct
