Nissan Green and Blue coolants can be safely mixed according to the following TSB:
Quote:
NTB09-040a - NEW BLUE NISSAN LONG LIFE ANTIFREEZE/COOLANT
SERVICE INFORMATION:
In calendar year 2009, Nissan began filling some vehicles at the factory with a NEW Nissan Long Life Antifreeze/Coolant (LLC) that is blue in color.
NOTE: LLC = Long Life Antifreeze/Coolant
The transition to this new Blue LLC continued though MY 2010. Beginning with MY 2011, all Nissan vehicles are filled at the factory with the Blue LLC.
• MY 2009 and 2010: Some vehicles are filled at the factory with Blue LLC.
• MY 2011: All vehicles are filled at the factory with Blue LLC.
Blue LLC is designed to have a service life of 7 years/105,000 miles for the factory fill, and 5 years/75,000 miles for subsequent replacement fills.
• Blue LLC one gallon pre-diluted:
P/N 999MP – LP25500P
- The one gallon containers are pre-diluted with 50% antifreeze and 50% distilled water.
- Do not add additional water when using pre-diluted Blue LLC.
• Blue LLC one quart concentrate:
P/N 999MP – L255QTP
- The one quart concentrate containers are intended for extreme cold weather application.
- Use the concentrate without mixing (do not add water).
- Add directly to the cooling system in specific amounts as directed on the container label.
Additional Information for using Blue LLC:
Blue LLC and Green-colored Nissan LLC (P/N 999MP-AF000P) are compatible with each other:
• Blue can be mixed/added with Green
• Green can be mixed/added with Blue
CAUTION:
• Adding Green LLC to Blue LLC will reduce/shorten the life expectancy of the Blue LLC to that of the Green LLC (4 years / 60,000 miles).
• LLC must always be used with demineralized or distilled water, otherwise the life expectancy of the LLC (Blue or Green) will be degraded and cooling system damage may occur.
