Looking for oil preference for this 12.5 Kohler Command from 1993 in a John Deere 38" garden tractor.
I know that the manual calls for 10w-30 2 qts. for the temperatures of which I will be operating and a spin on filter.
I have various 10w-30's. Does this engine care? Is it okay running Amsoil ASE Small Engine 10w-30 with older material gaskets? or will this introduce leaks? or should I stick to conventional or a Group 3 based synthetic instead?
Oils on hand in order of what I think I may run: all 10w-30
1. Amsoil (ASE) small engine
2. PP
3. QSUD
4. Valvoline white bottle conventional.
I will probably run the M1-102 filter or a Wix. Maybe a Fram XG3614, not sure, but I think the gold filter w/sure grip color looks odd with the yellow and green.
Service history is sketchy. A receipt from a local lawn mower shop, 3 years ago shows a WIX filter and PennzP 10w-30. It still has an old looking Wix filter on it so I guess it hasn't been changed in 3 years. Oil looks clean and at correct level. Prior owner parted with it due to no longer using/needed it. Runs good. Tires are worn, it has some use under it's belt. Well broken in. It has the yellow deck which I hear is better? I will be going over it top to bottom as it needs belts, tires, battery, fuel line/filter, air filter, new seat, etc.
Mowed with it 2x after jump starting (due to old battery). Running good with new fuel (w/startron fuel stabilizer).
2. PP
3. QSUD
