Originally Posted By: scoobie
5w20 oil runs better when cold, it will be significantly thinner at start up time than 5w30, which is when most wear occurs.
go to the website of the oil manufacturer that you wish to use, and compare the cold properties of 5w20 vs 5w30. the thinner oil also flows better at normal operating conditions, and with faster flow, the oil is better able to cool the engine. engine oil is extremely important for engine cooling, the 30 weight will flow slower, and the engine will not be cooled as well. also check the Interesting Articles forum on this site, and read Dr. Haas's course on oil viscosity. Most people here have discovered that Dr. Haas's conclusions have been borne out, with impressive UOA.
My vehicle is specced for 5w30, but I mix 50:50 5w20 to benefit from the thinner viscosity.
I wouldn't argue if you wanted to fortify the 5w20 by mixing it 50:50 with 5w30. however, just running straight 5w30 would be too thick in my view. And be sure to review the manufacturer's website for the ACTUAL measured viscosity, because the permitted range of 30 weight is pretty wide, and I would stay away from anything over about 10.6 or 10.8.
I put no faith in a UOA determining wear besides detecting an outright failure. It can only detect a certain size of particle. If the thin oil is causing more wear in the form of larger particles, it will not show up in the UOA. Until I see an engine teardown, I won't believe running the thin stuff in a car spec'd for a 50 or 60 weight won't cause excessive wear.
