New AC Delco compressor stiff, but everything works
New York City
I just had a new OEM AC Delco AC compressor installed on my car. The old one wasn’t internally bad just had a bad pulley and clutch
With my mechanic, we took the new one out of the box, and noticed it was stiff but able to turn by hand
Meanwhile the old compressor was easier to turn. You could turn the shaft with your fingers and without the clutch plate.
I decided to install it. Vacuumed system and recharged it with the proper R134a.
Everything works great. The temps go down to 45deg F on an 84degree day and there’s no loud noises from the compressor when the AC is engaged
But when I reach under the hood and try to turn the clutch plate, I can’t do it. It’s too hard. But the engine turns it fine. It’s not slowing down my engine either.
Should I stop using the AC and maybe swap the compressor again? Or am I just overthinking things? I’m worried this might grenade itself.
Did you add oil to compressor ? Most don’t come with oil. You add oil and turn compressor by hand to circulate oil before installing.
We did that. The sticker said there was 24CC of oil in it. But when we turned the pulley, nothing came out. It seemed dry. So we did the oil balance and added the right amount back.
In that case I'm sure it's fine. I guess it just needs to break in.
Ok small update.
Now when the car is “cool” or sitting a few hours, then I can turn the compressor by hand smoothly. Before it was always stiff even new in the box. Maybe it broke in or absorbed some PAG oil
But after running the AC for a few minutes, the compressor gets “stuck” I can’t turn it at all by hand.
However if the engine turns the AC compressor then it seems ok.
RPMs don’t dip
Tensioner isn’t wobbling
Belt isn’t squeaking
Small loss of MPG
No noise in the interior
No noise from the compressor
And the AC always blows cold (44 deg vent temp)
Sometimes I get the impression that the engine is working hard to turn the compressor, but I could just be overthinking
Either the “stiffness” is from the refrigerant pressure, or due to excess friction in the piston rings. Hard to tell.
