Originally Posted By: tinmanSC
It's hard to believe that one additional connection from outside the house would cause your network to go down.
It's not too hard to believe
I had an old neighbor (he moved out now....) that hopped on my network a couple times and apparantly was downloading "warez" and stuff over my network....my ISP called me up and I was so confused.....apparantly, he did it for like a month straight, every night after 10pm after we all went to BED....so my "pipe" was wide open for all his transfers......
But yea.....check out grc.com/securitynow - there's gotta be a way you can activate WPA/WPA2 or some sort of "password protection" on your router.....also go ahead and change the "SSID" (most commonly it'll be "linksys" or "2WIRE" or whatever your router brand is.....) as well as the password for your router login (the one you access in your web browser, usually by going to http://192.168.1.1....)
Then check out your port forwarding section and make sure he hasn't opened any ports on your network, or set up the "DMZ" mode...
portforward.com may also be a good site to check if you need help resetting the port forwarding stuff.
