I have a 2014 Honda Accord Hybrid (LFA1 engine, not related to other Honda L-series) with ~250k miles. Long story short, I removed the head 30k miles ago, and I don't think I got the torque-angle bolts exactly right. It has a slow coolant leak from the transmission side of the engine, and when you remove the oil cap at idle, there's a ton of crankcase pressure blowing out of the fill hole. (There's no oil in coolant or vice versa.) This causes it to idle poorly, but it runs perfectly under load. Luckily it's a hybrid, so it doesn't idle much, but winter is coming and I have to idle it a lot when cold to reduce piston slap (this thing is getting really worn out!)
Revving the engine reduces this pressure as the PCV system does its work. The coolant leak also stops when it's under load (it doesn't leak at all on long road trips)
I know I'm having lubrication issues as I assume the high crankcase pressure causes weirdness at the bottom end. The engine has started idling rougher in the last 5k or so, but still runs perfect under load. It makes a lot of noise at idle, but it's hard to tell what is bottom end issues and what is other noise from the coolant burbling out from between the head and the block and other weird noises this thing makes.
I have switched from recommended 0W-20 to 5W-20 with no change. Should I add oil stabilizer to get the oil to stick to the bearings better? Should I switch to an even thicker oil? Any ideas to reduce crankcase pressure at idle?
I searched all over and can't find anything like this, but if anyone knows of a similar thread, please let me know. Thanks in advance
