NAPA GOLD #1358 CUT OPEN
In the shop
Off a friends older sentra with 200,xxx on it. Was on for 2 ocis. 9,xxx miles on filter. Put a tough guard he supplied and some M1 0w30
Originally Posted By: edwardh1
what is the efficiency rating of the media?
NAPA Gold (same as regular WIX) are 95% @ 20 microns.
Looks like a dome end bypass valve on this model.
Originally Posted By: CR94
Oil color on that one looks peculiar---cloudy but not very dark. Any explanation?
Oil was dark looking, probably cause flash was on
Yah its looks like he's been running Swiss Miss.
At least I can't see any marshmallows.
LOL you don't Adam would let a good marshmallow go to waste.
Nitrile ADV and (nice looking) louvers in a NAPA Gold????
What is the world coming too
I have noticed that as well, use oil does not always photograph well.
I've always liked those Wix/Napa Golds myself. Used to buy the 51361s for a Nissan VG30E quite a bit.
Originally Posted By: blupupher
...louvers in a NAPA Gold????
Probably Mann+Hummel influence.
The 1358 is an outlier of the standard Napa Gold filter construction. My 'speculation' is because it's applications include many/majority OPE applications it uses a nitrile adbv, dome bypass and perhaps even the louvered centertube. Garak has shown those filter aspects in a thread of 1358 some time ago.
If I owned the Sentra I'd be using the 5/7356 (7317 equivalent). It's .7" longer with silicone adbv, thread end bypass (no spacer) and up to this point punched holed centertube. Not that the last matters to me. Personally haven't seen an application where the longer 7317 equivalent(s) wouldn't work in a Nissan.
That said, looks like the 1358 did it's job over two ocis.
