Motor is a 2004 Cummins ISX15.Wanting to increase oil pressure a little bit.Which would be the better choice?
Oil changes would $246 with Rotella and $270 with Mystik.
Everything I could find online indicates that the ISX has an ECM controlled low pressure, high volume oil pump. 20 psi at hot idle is normal for these and so is 35 while cruising.
The Mystik only has a CI-4 plus certification, whereas the Rotella is CK-4. API CI-4 would have been the current standard when your engine was produced, so it will be fine, but CK-4 is a more stringent standard. I'd use the Rotella.
