Originally Posted By: BrocLuno
Originally Posted By: Ducked
I have a roughly 1:1 mix of straight CPC SAE 40 and Mobil Delvac MX 15W40.
It was an accident, but it seems to have a few things going for it. Its been in about 5 years now and I'm thinking I might change it soon to get the particulates down.
The CPC may be group 1, and has a low TBN (about 6 IIRC) but the high TBN and detergent of the Delvac should compensate for that. The polarity of the Grp 1 MAY help dissolve varnish (I had some) and the Delvac MAY keep any varnish produced by the 40 in suspension.
Less speculatively, the 40 will resist shear, and pretty much by definition, it won't have VI's in it that could be incompatible with those in the Delvac.
I'd guess the mix will be very roughly in the 20W50 zone, though this isn't calculable.
I have another 4L of the Delvac but may not be able to get any more, but so far the 40 is still available, so I could use it to extend the Delvac to two oil changes.
This all tempts me to continue this mix deliberately after I change the oil, but I dunno if I will.
Sounds like a plan. SAE 40 and 15W-40 would not likely yield a mix with an Op Temp viscosity higher than either so I'm guessing it's more like a 25W-40 or 30W-40 when all done. Nothing wrong with that in your environment. Go for it
Sorry, the 50 was a habit-formed typo. Agree should be 40. Re lower figure, arithmetic mean is around 27 but its supposed to be skewed to low side, so my guess is somewhere in the 20-25 range.
