Originally Posted By: Gebo
Without mentioning any names, I have noticed my ATF NEVER gets hot. I pulled a lawnmower on a trailer for 2 hours on the interstate and my ATF was barely warm. I know that's good. BUT...
How do I determine proper fluid level? This vehicle has a dipstick so I can check it. Do I keep it between the "COLD" hashmarks or do I add up to the "HOT" hashmarks? I ain't making this up. As soon as I got back home from the haul, I kept 4Runner running, shifted through all the gears, pulled the dipstick out, wiped it off, reinserted and the reading is slightly above the upper "COLD" marks but no where near the "HOT" range.
If I read this right, you're referencing dipstick markings to determine whether your transmission is hot. Thats not what the refrence marks are for. They tell you the level of the transmission fluid when its "cold" (contracted, recently started) or "hot" (expanded, after towing, or an hour on the highway on a hot summer day). So from what you described, its slightly low. Maybe 1/2 qt. get it hot again and add some fluid until you are just below the "hot" line. Or just leave it alone. Better a little low than too high..
