Wondering if this is beyond repair? If not, if someone would have a recommendation on how to fix. This is a 22 inch push mower. Looks like the engine is held to the deck in three places, two of the three places look like the attached picture.
Not unless you're willing to put more work into it than its worth. It decayed from the underside from the grass holding moisture against the metal. You'd probably almost have to fabricate an all new deck.
Better off finding a deck with a blown motor.
To prevent it in the future, clean the grass off the underside after mowing.
Should be easy to find a decent deck with a blown motor. Just look around for the Briggs and Stratton lubed for life engines. They usually self destruct in 3-5 years.
I had the same problem, finding a replacement deck was actually pretty easy. I took a few rides around the neighborhood the mornings of heavy trash collection.
You will be able to find end of season discounted mowers real quick.
Example, no tax, free shipping to your door and it has a decent Briggs & Stratton, not one of those 125/140 CC ones.
I purchase a new mower at the start of summer , with the B&S lubed for life engine . It will have oil changes every year .
Originally Posted By: MParr
It’s toast! Notice the crack in the engine’s mounting flange. Put it out by the road, some scrapper will pick it up.
