Motul X-Max 5w-40
NY, USA
Does anyone have experience with this oil?
How is it "related" to X Cess 5W-40
What class synthetic is it?
Why does it not appear on any of the Motul sites?
The oil obviously exists....just not on Motul's main or most websites. Strange that they would concurrently sell /manufacture X cess and X max. Supposedly then there would be markets for the two different oils.....but who would use X cess over Xmax?
Additionally I do not think that a re-seller's ad for oil is a solid source of information about base-stocks.
BobFout said:
http://www.motul-oil.co.uk/pdfs/synthetic-engine-oil/8100_X-max_5W40_TDS_(GB).pdf
Interesting developments : Motul UK no longer lists 5w-40 X-max as available and has just changed the specs on Motul X-cess: it is now SM rated and BMW LL 01/ MB 229.5.
What happened to X-max? Was it just a stop-gap re-formulated X-cess?
Listed is 0w-40 Motul X-Max, now a low SAPS oil.
http://www.motul-oil.co.uk/products-synthetic-engine-oil.php
What is the big deal on this oil? Just use Rotella t-6 IMHO. but Im always willing to learn>>>>>>>>>>>>>>>>>>>something.
I stay away from low SAPS oils.
Originally Posted By: felixthecat
Rotella T6 is not low-SAPS.
http://www.shell.com/home/Framework?site.../t6_detail.html
See section titled "Low emissions"
A low SAPS sparker oil is very different from a mid SAPS diesel oil. Low emissions for the diesel world is different.
T6 (and other CJ-4) oils have more ZDDP/SAPS than "high-mileage" sparker oils that are purported to be "higher in Zinc" etc.
ZDDP levels in CJ-4 are more like ACEA A3/B4. (and the other older Euro specs)
Gasoline engines do not require any limits to SAPS ( imposed to protect diesel particulate filters) but only limits related to API SM certification.
Given that formulation restrictions may have a major impact on a lubricant's performance and that the replacements for these additives maybe less effective and introduce performance compromises and conflicts, I will stick with oils specifically designed for gasoline engines.
You'll have to look elsewhere than Euro oils for this.
If it's additives you're worried about, CJ-4 additive levels are very similar to older Euro gas/diesel oils (A3/B4, 505.00/502.00, 229.5/229.3/LL01).
When I said "specifically designed" for gasoline engines I mean meeting ACEA A3/B4.
The addition of diesel particulate filters has generated a whole range of oils meeting ACEA C2/C3 in addition to A3/B4. These are the oils I would stay away from.
May I ask why Shell Rotella seems to be regarded as a panacea for just about any application ?
Aren't additive packages carefully balanced and always a compromise? Then why use an oil that was specifically not designed for your particular application?
