the new SP version is very impressive , can not understand why Motul did not pay to certify it for A40 or even the new C40
Well it probably would not pass the tests or specs required.
i really doubt it , its matter of time and fees i am sure , it did happened before 5-6 years ago with the 5w40 Xcess and ended up being certified laterWell it probably would not pass the tests or specs required.
The bottle image also says API SNGroup IV and V with Ester in the mix hardly gets street use certification for obvious reasons, NOACK is a better determination of oils
being PAO , Ester based https://bobistheoilguy.com/forums/threads/motul-noack-list.274856/
compared to the SN formula as well as my oil analysis experience with this oil since 2018 , used 2016 Cayenne turbo S.
sometimes people fall for looks good on paper vs proven results.
for Porsche A40 applications HTHS, Full SAPS , Low ash , decent VI are best matched using this oil .
my issue is warranty that i purchased valid through 2026 .
So yes this oil is impressive but sadly i need to stock up on the SN version for now.
Note the bottle image on Motul website still have the A40 so maybe its matter of time.
We really have no idea. They have multiple A40 oils already, so I doubt it's just cost.i really doubt it , its matter of time and fees i am sure , it did happened before 5-6 years ago with the 5w40 Xcess and ended up being certified later
Sadly only one 0w40 A40We really have no idea. They have multiple A40 oils already, so I doubt it's just cost.
Fees are none issue.i really doubt it , its matter of time and fees i am sure , it did happened before 5-6 years ago with the 5w40 Xcess and ended up being certified later
Why do you think it’s majority Group IV/V? Even if it was, it has the other major approvals so clearly that isn’t a reason.Group IV and V with Ester in the mix hardly gets street use certification for obvious reasons, NOACK is a better determination of oils
That Noack is higher (9.8%) than M1 FS 0W-40, at 8.8%.Group IV and V with Ester in the mix hardly gets street use certification for obvious reasons, NOACK is a better determination of oils
And yet, 100% Group III yields KV100 of 13.5 and HTHS of 3.8. X-Clean HTHS is 3.9.That Noack is higher (9.8%) than M1 FS 0W-40, at 8.8%.
If the SDS for the "SPECIFIC A40" lube is the same, it's 25-50% Group III, 25-50% PAO. The 5W-40 X-CESS is all Group III.
A tell is probably the use of the words "Synthese-Technologie" rather than "vollsynthetisches".
If you look at X-Cess Gen 2, X-Clean Gen 2, and the Specific LL-01 FE, they have really high HTHS for their KV100 despite being all Group III. The Specific LL-01 FE particularly has a very high HTFS if you plug the numbers into Gokhan's spreadsheet. Too bad the additive packs are old school.And yet, 100% Group III yields KV100 of 13.5 and HTHS of 3.8. X-Clean HTHS is 3.9.
Base stocks could be provided by numerous companies, even those that make their own oils but are of lower performance.If you look at X-Cess Gen 2, X-Clean Gen 2, and the Specific LL-01 FE, they have really high HTHS for their KV100 despite being all Group III. The Specific LL-01 FE particularly has a very high HTFS if you plug the numbers into Gokhan's spreadsheet. Too bad the additive packs are old school.
I wonder how this is achieved or what supplier they are using? Just thicker base oils?
Yup, easier to do with the narrower spread for sure.And yet, 100% Group III yields KV100 of 13.5 and HTHS of 3.8. X-Clean HTHS is 3.9.
Their GEN2 stuff on paper looks really good.Yup, easier to do with the narrower spread for sure.
I just noticed that X-Clean Gen2 lost Porsche C40 when going to API SP also, so the X-MAX change is probably not just a coincidence. X-Clean Gen2 looks pretty nice... 3.9 HTHS with relatively low KV100, mid SAPS, API SP.Their GEN2 stuff on paper looks really good.
I have like 30qt of it, so we will see what UOA shows up.
