motul says you can mix this oil.
5W-40
New 300V series is racing lubricant for racing cars.
MOTUL has developed “Double Ester Technology” for new 300V series, superior to complex ester that recognized the best base oil for engine oil up to now. Double Ester Technology, made by carefully balancing the ratio of complex ester and the newly developed macromolecular high polymer ester, enable base oil more wide-ranged, and delivers high output performance and superior reliability.
Also by carefully selecting the right polymer, “0% shear loss*” can be achieved.
*Diesel Injector method (CEC L-14-A-93), a standardized testing procedure for a lubricant’s shearing force.
Mixing with another viscosities is not recommended.
All-round use, designed for handling stable oil pressure preservation and sharp response.
Compatible with a wide selection of engines — naturally aspirated, high torque turbo and cars that produce average to high levels of exhaust fumes.
SPECIFICATIONS
Product 300V POWER
Feature 100% Synthetic, Double Ester Technology, 0% Shear loss, can mix, for cars only.
SAE/DOT Standard 5W-40
Specification Exceeds all existing standards.
Maker's Approval —
Compatibility For engines that run circuit and street races
NEXT
[email protected]
