Thank all of you for your thoughtful comments. Here is what I conclude:
1. No one offered a theory as to why TBN remained so high on a 9,000 mile run. So I'll offer my own speculation. I'm a short-haul driver. The basic (that is, alkaline) chemicals in the oil require more time at operating temperature to do their work than I can give them. That would also partially explain why the Ford IOLM seems to continue to reward me with a slow-moving clock for a few days after I take one of my infrequent long trips.
2. I'm not sure if I am impressed with the IOLM or if the Motorcraft oil is so stout it doesn't make any difference. It's true that the IOLM seemed to be pretty accurate, again, but I was creeping close to the automatic condemnation level of 10,000 miles. It may have been simply counting down the miles by then. I could have jumped in the car driven a thousand miles and it wouldn't have missed a beat based on the UOA. I conclude that the Motorcraft oil and the IOLM are both overengineered.
3. I need to step it up on changing the air filter. the undissolved solids number was very low, and silicon was about a third below average levels, so I'm not too worried. I know I changed it at least once before. Has it really been 30,000 miles? It didn't look so bad. I changed it on solar eclipse day. Maybe I should make a mental note to change my air filter every time there is a solar eclipse. I'll look around for some of that sealing grease you guys were talking about and maybe try and be a little more careful in the air filter department.
So, I learned something. There's a concrete step for me to take to take better care of my car. It doesn't involve mindlessly changing my oil at earlier and earlier intervals.
