I have a ATV which has a manual trans, So its got gears and a wet clutch and it gets used hard, ATV's have alot of shock loading. It calls for 10w30 motor oil or ATF! Here is the thing, After only a few short rides using what the manual calls for the oil turns to glitter, So I said the [censored] with that and started using #267 schaffers oil which is 80w-90 which is what most manual trans use. I been riding now for 35 hours and the oil still looks new and the wet clutch does not slip at all and it shifts just as good maybe even alittle easier when warm. What gives exactly when manufactures tell you to use a oil that causes excelerated wear which I would seem to think, My ATV has a forum and they were all like no don't use that use flex drive 10-30w or belray gearsaver 80w, Why? I told them, about the glitter thing and noone wants to argue that with me. this stuff has been going flawless.
