$5400 for a transmission [6L80] in my 2016 5.3 Tahoe from the Stealership
And you hadn’t even seen Mesquite yetI rode in a Greyhound bus in 1998 from Hudson Wisconsin to mesquite Texas that had a green leaker. After about 30 minutes I was ready to get off and walk.
The most expensive repair I have ever needed was having the torque tube replaced on my Corvette. Up here that’s about a $10,000 repair bill because it is about a 16-20 hour job. Lucky for me that happened under warranty and cost me nothing. If it happens again I won’t get a dealer to replace it, I have a good friend who is a licensed mechanic and Corvette expert and works out of his home. He’s probably replaced 25 or 30 torque tubes and would be half the price of the dealerships
In early 2020, I paid $ 3,200 to a guy in Fort Mohave who was supposed know what he was doing for turbo and other work on my Jetta TDI. Bolts not tightened, no power. Less than a month later I paid $ 4,800 to someone in North Las Vegas to do the job right. The guy in North Las Vegas said he would testify if I wanted to sue the Fort Mohave guy.
I gave it serious consideration, but settled on telling everyone, everywhere how bad he is. Like I said, the German guy in Fort Mohave.Did you sue the idiot ?
$1616 for my Jeep tires … no certificates …I paid nearly a thousand dollars for tires once
The torque tube is one thing that GM can’t seem to get right, they have been failing on the C5s, C6s and C7s. Because of where they sit, they generate a lot of heat and it ruins the bearings. In my case I was hearing a rattling noise at idle. If left too long it gets much worse but I caught it early.Why did it need replacing ?
I don't really consider tires a "repair" but I am pretty much DIY on everything else. Except alignment. I think I paid around $150 for an alignment before.$1616 for my Jeep tires … no certificates …
i have several i actively use to make a living.Who's still running one of those? They outlawed them here over 30 years ago,
