Consider the following:
1995 Oldsmobile Cutlass, 3.1 V-6 -
Fram: Part No. PH3387A
Anti-Drainback Valve: Yes
Flow Rating: 3 GPM
Gasket Inside Diameter: 2.47 in
Gasket Outside Diameter: 2.75 in
Gasket Thickness: .19 in
Gasket Usage: Base
Height: 3.36 in
Inside Diameter: 18mmx1.5mm Th'd
Outside Diameter: 2.98 in
Driveworks: Part No. DW-111
Filter Bypass Relief Valve: No
Filter Type/Category: Spin On
Gasket Inside Diameter: 2.398 in
Gasket Outside Diameter: 2.752 in
Height: 3.36 in
Maximum Burst Pressure: 300 PSI
Micron Rating: > 5 mc
Recommended Change Interval: Use OE Recommendation
Spin On: Yes
Thread Size: M18X1.5-S
Now, compare that with the recommended oil filter for a 1986 Chevy Astro Van, 4.3 V-6
Fram: Part No. PH3980
Flow Rating: 3 GPM
Gasket Usage: Base
Height: 4.94 in
Driveworks: Part No. DW-4011
Height: 4.74 in
Spin On: Yes
Other than filter height, (3.36 vs 4.75) - these filters seem to be exactly the same. Therefore, it seems that I could use the filter recommended for the 1995 Oldsmobile 3.1 V-6 for the 1986 Chevy Astro 4.3.
Not looking to buy these filters, but looking to use filters that I already have.
Opinions?
Flow Rating: 3 GPM
Gasket Usage: Base
Height: 3.36 in
Height: 3.36 in
Spin On: Yes
Flow Rating: 3 GPM
Gasket Usage: Base
Height: 4.94 in
Height: 4.74 in
Spin On: Yes
Opinions?
