Would you say that all UOAs on the same engine, varying just the oil brand, will be the same?
Is it unreasonable to say that different engines might respond differently to different oils?
UOA's lack the resolution to allow you to discern meaningful differences in wear performance between different oils, that's not their intended purpose, but unfortunately, believing they can results in many people chasing their tail.
Engines are complex mechanical devices with various systems in them that can indeed respond differently to different base oil blends, additive combinations, FM formulations...etc. This can result in subtle differences that may, or may not, be apparent to the end user. This could be something as simple as increased/reduced volume of consumption due to the PCV setup, or an apparent reduction/increase in NVH due to the FM interaction with something like cylinder deactivation. However, UOA's aren't going to give you any insight into this, nor does it mean wear performance is going to be any better/worse.
Personal anecdote: Years ago, I had very high levels of consumption with AMSOIL AZO 0W-30 in my Expedition 5.4L. M1 0W-30 didn't consume at all in the same vehicle, nor did Motul 0W-30. I did several OCI's to see if the consumption would taper off (which it can with a chemistry change), but it never did, so I had to stop using that oil in that vehicle. Do I know why that oil consumed? No. Do I know HOW that oil consumed? Also no. Had I done UOA's on that oil, would it have given me valuable insight into this phenomenon? absolutely not.
With something like consumption, you at least have something quite tangible, and, if it can be mitigated by using a different branded product, that seems quite reasonable. With something like noise or "feel", you start to head down the sensory rabbit hole, and, as you note in your subsequent reply, this doesn't necessarily correlate (heck, it could anti-correlate if we are throwing out theories) with the performance of the product. This is why approvals and controlled testing are valuable.
Lucas is often promoted as being "good" because, from a sensory perspective, it can reduce NVH. Well, we know it's just heavy Group I brightstock, cheap VII polymer and zero additives, effectively diluting (reducing the effectiveness) of the additive package of the host product that controls wear, handles deposit prevention...etc. All the things that we require a fully formulated oil to do, Lucas compromises. Here we have an anti-correlation, where the product "feels" like it's good, but in fact, is quite the opposite.
