Consider the lab that ran the test.That’s a 40-weight, not a 50-weight oil.
Castrol Edge Full Synthetic 0W-20 | SP | 01/22/22 | Blackstone | 0 | 0 | 0 | 0 | 0 | 0 | 65 | 0 | 0 | 0 | 18 | 0 | 125 | 7 | 3 | 911 | 761 | 710 | 834 | 0 | 52.8 | 8.12 | 425 | 6.4 | ||||
Castrol Edge Full Synthetic 0W-20 | SP | 03/31/22 | PQIA | 0 | 0 | 0 | 0 | 0 | 0 | 73 | 0 | 0 | 0 | 20 | 4 | 138 | 12 | 4 | 943 | 722 | 758 | 828 | 0 | 8.6 | 9 | 11.9 | 170 | 5518 |
Amsoil SSO 0w-30 | SP | 07/27/21 | WearCheck | 0 | 0 | 0 | 0 | 0 | 0 | 201 | 0 | 0 | 0 | 0 | 0 | 353 | 5 | 3 | 1162 | 816 | 620 | 755 | 0 | 10.77 | 10.2 | |||
Amsoil SSO 0w-30 | SP | 08/05/21 | Blackstone | 1 | 0 | 0 | 0 | 0 | 0 | 204 | 0 | 0 | 0 | 0 | 1 | 316 | 6 | 6 | 1180 | 909 | 692 | 774 | 0 | 61.1 | 10.67 | 440 | 7.9 |
Pennzoil Ultra Platinum Full Synthetic 5w-30 | SP | 03/04/22 | PQIA | 1 | 0 | 1 | 0 | 0 | 0 | 86 | 0 | 0 | 0 | 0 | 0 | 310 | 4 | 0 | 1164 | 753 | 708 | 789 | 0 | 10.1 | 8.5 | |||
Pennzoil Ultra Platinum Full Synthetic 5w-30 | SP | 04/09/22 | Blackstone | 1 | 0 | 1 | 0 | 0 | 0 | 91 | 0 | 0 | 0 | 2 | 1 | 273 | 4 | 1 | 1189 | 846 | 694 | 820 | 0 | 59.1 | 9.97 | 445 | 7.4 |
I've seen the Polaris oil is also less than stellar.Thanks for this. This is the oil that I run in my Polaris ATVs. M1 FS X2 5W-50 is wayyyy cheaper than the Polaris PS4.
Maybe a reason M1 dont show it on typical spec And aslo arent the Porsche approval A40 based on xx-40 viscositySAE j300 would not even allow it to be rated as a 50 under 16.3cst. For whatever reason Blackstone always shows viscosity as lower than it really is. Their "values should be" isn't even right either. Should say 16.3-21.9.
It is based on a minimum HT/HS value. It may have allowed grades but the technical basis is the HT/HS.Maybe a reason M1 dont show it on typical spec And aslo arent the Porsche approval A40 based on xx-40 viscosity
don't now if i go with mobil delvac 1 5w-40 or m1 5w-50 in my land cruiser (diesel), Probably the m1 5w-50 have work good in your Rover diesel?Thanks for posting, my go-to oil on the Porsches and the Rover diesel, but after a discussion w/ a few other P'car folks, I may switch to Redline 10w-50...
Hi, yes, but the engine has less than 10k mi/16K km. The oil pressure is very high, so I am thinking of the Delvac 5w-40, but I have not had any issues w/ the 5w-50. Both are very good choices. Given your local climate, I may go w/ the 5w-40, but either will be excellent choices.don't now if i go with mobil delvac 1 5w-40 or m1 5w-50 in my land cruiser (diesel), Probably the m1 5w-50 have work good in your Rover diesel?
