Previous oil changes were:
575 factory fill changed out with Castrol GTX 5W-30 and Mobil-1 M1-209 oil filter.
3010 Castrol GTX 5W-30 changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
6025 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
9025 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
12029 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
15057 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Wix 51372 oil filter.
19928 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Wix 51372 oil filter.
25000 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Motorcraft FL-820S oil filter.
30000 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Motorcraft FL-820S oil filter.
35036 Mobil-1 5W-30 SS (SM I believe) changed out with Mobil-1 5W-30 EP and Motorcraft FL-820S oil filter.
40050 Mobil-1 5W-30 EP changed out with Mobil-1 5W-30 EP and Motorcraft FL-820S oil filter. This was the first run of M1 Extended Performance.
45049 Mobil-1 5W-30 EP changed out with Mobil-1 4 Qts. 5w-30 EP + 1 Qt. 15W-50 EP mix and Motorcraft FL-820S oil filter. VOA is located here for that mix: 4 Qts. Mobil-1 5W-30 EP + 1 Qt. Mobil-1 15W-50 EP mix
50049 Mobil-1 (4 Qts.) 5W-30 EP + (1 Qt.) 15W-50 EP changed out with mix of same and Motorcraft FL-820S oil filter. VOA for mix used for 45049-50049 interval above - this mix should be same.
55805 Mobil-1 (4 Qts.) 5W-30 EP + (1 Qt.) 15W-50 EP changed out with Mobil-1 5w-30 EP and and Motorcraft FL-820S oil filter.
Results:
My comments: Well, driving more normally seems to definitely have helped...I certainly didn't baby it all this time around, however I didn't beat the snot out of it like I was doing last time. This is a pretty ho-hum UOA IMHO...can't really draw any conclusions here other than that running a mid (VOA) to thick (UOW) 30W in the newer Ford 4.0L SOHC V-6's doesn't necessairly mean that it's better for the engine, or worse, than a typical thin 30 weight. Just in case this UOA turned out like the last one, I put in 5 quarts of Mobil-1 5w30 EP and another Motocraft filter. The UOA, which I'll run to 5,000 miles, on this I'm sure will look just like the past 5,000 mile runs of (all) 5w-30 Mobil-1 EP w/ Motorcraft filter I've run. Providing that is true, the next run after that is definitely going to be another 5,000 mile run of 5 quarts Mobil-1 5w-30 EP but this time using Mobil's Extended Performance oil filter. We'll see how that changes the results of a UOA. After than, I'll probably switch back to Motorcraft filter, and then pick another oil. So, the folks that have been wanting to see a non-Mobil oil run in this are going to get their wish relatively soon (with the holiday's, it'll probably be mid-late 1Q '06).
Also, for the push it out to a longer OCI folks, I unintentially - although I knew I was doing it - pushed this OCI past my typical run of 5,000 miles (I hope Ford isn't logging this info...
) Didn't really go much past 5,000 miles, but a little counts, right?
Someone had asked me about consumption in an earlier thread, and I can confirm I did have slight consumption this time around...I'd guesstimate maybe 1/4 to 1/3 of a court...no more than half a quart, and that'd be pushing it I think. I'll keep an eye on this run of just 5w-30 to make sure it's not something else causing the consumption, like a PCV or something like that.
Chuck
Results:
Blackstone Comments: This oil has gone a little thick on you. This viscosity would be typical of a 10W/30, but it doesn't seem to be hurting anything that we can see. You've pushed on up to 5756 miles on the oil and the wear metals stayed steady, mostly below average levels (see universal average wear), so this oil is getting the job done for you. Average miles oil use for one of our samples from this type engine is 4500. The TBN was 5.8, still showing plenty of active additive remaining. Go on up to 6500 miles for the next sample. Wear should still look good.code:
M1 oil type: EP-SL EP-SL EP-SL EP-SL SS-SM SS-SM SS-SL SS-SL SS-SL SS-SL
Sample Date 11/05 09/05 06/05 05/05 03/05 01/04 09/04 06/04 03/04 10/03
Truck Milage 55805 50049 45049 40050 35036 30001 25000 19928 15057 9025 Universal
Oil Milage 5756 5000 4999 5014 5036 5000 5072 4871 3028 3000
Aluminum 3 2 3 3 3 3 3 3 4 4 4
Chromium 1 1 1 1 2 1 1 1 1 1 1
Iron 11 9 8 11 16 12 11 14 19 16 16
Copper 7 5 2 3 4 4 4 5 3 3 6
Lead 0 0 0 1 1 1 1 1 2 0 4
Tin 0 3 1 1 2 1 1 3 2 3 1
Molybdenum 73 79 90 85 66 60 77 59 69 77 49
Nickel 0 0 0 0 0 0 0 0 0 0 0
Manganese 0 0 0 0 1 0 1 1 1 1 1
Silver 0 0 0 0 0 0 0 0 0 0 0
Titanium 0 0 0 0 0 0 0 0 0 0 0
Potassium 0 0 0 0 0 0 0 0 3 1 3
Boron 160 150 199 160 98 120 163 138 157 155 50
Silicon 9 9 10 9 9 9 12 11 10 9 9
Sodium 11 8 6 8 5 5 8 6 4 7 12
Calcium 2540 2866 3276 2833 2417 2412 2860 2938 3120 2887 2102
Magnesium 16 14 15 12 15 6 14 13 14 20 187
Phosphorus 814 838 880 750 678 608 761 756 730 799 747
Zinc 933 1050 1005 900 694 677 893 909 825 910 894
Barium 0 0 0 0 0 0 0 0 0 0 1
SuS@210F 68.3 66.9 63.9 62.4 60.1 59.8 61.0 60.9 59.3 61.3 should be 56-63
Flash_F 420 420 425 410 400 370 410 410 385 385 should be >365
Fuel %
Antifrz% 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 should be 0
Water % 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 should be
Insoles% 0.2 0.1 0.2 0.3 0.3 0.4 0.2 0.3 0.3 0.1 should be
TBN 5.8 6.1 5.3 5.4 4.4 5.7 5.7 5.8 5.4 8.5
Chuck
