2004 Toyota Sequoia 4.7L V8 2UZ-FE 111,981 miles.
20,979 miles OCI.
Mobil 1 5w30 EP.
Donaldson P169071 oil filter with external filter magnet.
New Toyota air filter installed at 92,133 miles.
After my last OCI of 15,708 miles, decided to push this one a little further.
Oil in service for 13 months of local New England driving - mostly short trips of 5 to 20 miles plus some road trips and infrequent towing of 3,500 to 4,500 lbs trailer.
2-1/4 quarts of oil added in 20,979 miles. 1 quart added after 5,307 miles. 3/4 quart added after 14,947 miles. 1/2 quart added after 18,929 miles. Original fill was intentionally low to allow later oil addition to refresh the additive pack, so oil usage over OCI was actually about 1-1/4 quarts.
Filter cut open. Nothing visible in filter pleats, can clean and small pinch of dust-like ferrous particles visible at magnet location.
Aluminum 4
Chromium 0
Iron 16
Copper 3
Lead 1
Tin 0
Molybdenum 87
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 4
Boron 58
Silicon 17
Sodium 17
Calcium 2210
Magnesium 11
Phosphorus 599
Zinc 718
Barium 0
SUS Viscosity at 210F 64.1
cSt Viscosity @ 100C 11.36
Flashpoint in F 390
Fuel % Antifreeze % 0.0
Water 0.0
Insolubules % 0.4
TBN 3.3
Blackstone Comments:
You ran this oil fill out to 20,979 miles in your Sequoia, and the engine barely even noticed! Iron tracks with oil use, so the 16-ppm found in this sample is a normal level and not a cause for concern. The viscosity was a bit high for a 5w30 oil, but with wear at these good levels, we can’t complain. No coolant or fuel was found in the oil. The TBN at 3.3 shows some active additive remaining for a longer run. Try 22,000 miles on the next fill and then send in another sample to monitor wear. You have a great-wearing Toyota engine at 111,981 miles.
20,979 miles OCI.
Mobil 1 5w30 EP.
Aluminum 4
Chromium 0
Iron 16
Copper 3
Lead 1
Tin 0
Molybdenum 87
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 4
Boron 58
Silicon 17
Sodium 17
Calcium 2210
Magnesium 11
Phosphorus 599
Zinc 718
Barium 0
Flashpoint in F 390
Water 0.0
Insolubules % 0.4
TBN 3.3
