MMO in trans fluid?
Call it NNJ
Would MMO do anything to free up transmission internals a la A-RX if put into a transmission?
I have a 4L60E. and somewhere, either the lines or it is leaking.. unknown. And it is getting low on fluid, I can feel it. And I have some MMO.
Try Lubegard red its the better than both products you mentioned in transmissions. If you don't want to invest in LG top it up with ATF.
They wouldn't both be red if this weren't meant to happen.
But really, no.
Maybe you should hose down your whole engine compartment with this stuff:
Again, but really, no.
Originally Posted By: Chris142
Fix the leak
+1 I read his opening statement again. If its leaking enough to feel its low, fix the leak or you'll be fixing more than a leak.
So what I am reading is that it shouldnt matter, 12oz. of MMO..
And I have no idea where my leak is from, though maybe the lines.
I think i really need to get those radiator supports so whatever is screwed in can stay that way, yes? Cost?
You are missing the sarcasm. Do not put MMO in!
I put in some MotorKote, MMO and SpectrumPlus Automatic Trans Sealer and what do you know? Shifts smoothly. YMMV
