Originally Posted By: SteveSRT8
Virtually every high performance engine and almost every forced induction engine have significant fuel dilution. So do Direct Injected motors.
I have never seen any data to link fuel dilution to engine damage.
Please define "significant".
As for the second part, take your case with Amsoil:
http://www.tsadvancedsynthetics.com/facts/Fuel_Dilution_Causes_and_Effects.htm
Quote:
Fuel dilution of motor oil can be very detrimental to an engine and its components. Under normal operation, the motor oil film is keeping metal surfaces and their asperities separated to prevent wear.
All of the following can occur if fuel enters the crankcase and contaminates the motor oil:
• Reduced oil viscosity
• Disrupts the oil film strength causing metal asperities to contact each other promoting engine wear, particularly in the cylinder/ring area
• Increases volatility (in very extreme cases it can lead to a crankcase explosion)
• Weakened lubricant detergency
• Accelerated lubricant oxidation
• Varnish formation
• Acid formation/corrosion
• Low oil pressure
