Originally Posted By: HKPolice
Originally Posted By: KingCake
50/50 is the worst way to make a blend. You should either have a majority of conventional or a majority of synthetic.
This is the only correct post here. Mixing your own oil is never a good idea because you don't know how the different additives will react with each other. Off the shelf semi synthetic oils are made from scratch using additives tailored for a mixed base stock.
For example: Group2 base stock has a lower VI than Group3, so a conventional oil will need more VII than a synthetic oil to reach 5w30 grade.
If you mix conventional 5w30 with synthetic 5w30 then the final grade could be more like a 10w40 because the extra VII from the dino oil will thicken up the synthetic base stock.
Sure, the homebrew mix will work fine but it'll be inferior to off the shelf semi synthetics with an unpredictable viscosity.
I intend to take another sample at 215k, but according to Blackstone the homebrew mix at the 155k oil change looks pretty good (see below). Viscosity looks about right.
I break all of the rules in that I change my oil filter every other change, use a Fumoto valve, mix my own oil and add in 4oz of Tufoil.
As a side note, the early couple of changes were Mobil 1.
