Originally Posted By: S65AMG
Nissan developed parts of the GTR using M1 0W40 and specifically talk about recommending it's usage to guarantee performance. So that's a little bit beyond just an OEM relationship.
No, that's a somewhat typical OEM relationship with Mobil actually. GM does the same with the Corvette stuff, Honda did the same with developing their HTO-06 spec....etc. Mobil has the money to work hand-in-hand with OEM's on this stuff every step of the way. That's one of the reasons they are such a great partner to work with.
Quote:
While you claim not to understand what I'm getting at, it's a simple point and I think you're just stirring the pot. I'm not claiming for a minute that VI is the most important thing so I don't know why you decide to attribute that to me. I am pretty certain that you and many others commenting here are not such great experts that you know for sure which elements are most important and to what degree.
And you do? I mean we are all just [censored] into the wind here to some degree. I don't formulate lubricants for a living, but I do listen to the guys that DO know what they are talking about. One would be Molakule, who DOES formulate lubricants for a living and has never mentioned that VI is some holy grail. And Doug Hillary, who did extensive fleet testing for ExxonMobil and again, he never mentioned VI as being some earth shattering factor in his testing either
Quote:
I'm just refering to some interesting evidence, namely that the most highly thought of Euro oil, that is suitable for racing, happens to have the highest VI in it's class. And that it had an even higher VI when the modifiers were not as stable.
We don't know if it was the VII's that were "not stable" or that the VISOM base oil used in the SN version is just heavier than the PAO base they used in the SM version and subsequently the oil simply doesn't shear like the SM version did. I doubt there's a significant amount of polymer in M1 0w-40, SM or SN.
Quote:
So some experts, whose relative expertise compared to you and me is far greater and more significant than your relative expertise to me, placed some importance to a high VI.
Which experts? Again, I cite my Ferrari example and SOPUS.
Quote:
They even made VI the first point in a presentation they did about the advantages of synthetic oil. In many people's books, the order in which things are talked about signifies their importance. That of course might speak more to relative importance rather than absolute importance.
Well a naturally higher Viscosity Index is certainly an easy thing to point out, wouldn't you agree? An oil thickening less with cold and thinning less with heat is certainly a trait I'd make it a point in mentioning. That was touched on by me earlier, when I said that M1 0w-40 had a
relatively high VI. Much of that VI is likely NATURAL, and a byproduct of the base oils used! I'm betting PU 5w-40 has next to zero polymer in it (it also has a PHENOMENAL NOACK) because of the GTL base stocks employed by SHELL. The natural VI of the product might not be as outstanding as that of M1 0w-40, but I bet the lubricant is more shear stable. There are ALWAYS trade-offs. However, that's one of the beautiful things about synthetic base stocks, and why they mentioned it, and that is that you don't need to use a lot of polymer to get a relatively high VI lubricant! That's an important point to consider! I'd much rather have more high quality base oil and less polymer in my lubricant. With modern synthetic base oils, that's exactly what these companies are doing. And there are other benefits, like low NOACK. M1 0w-40's of 8.8% for the SM version is still incredible. And that's a base oil function.
Quote:
But hey if it makes you feel better to reply to me with a superior attitude, then go ahead. In the scheme of things it matters not.
I don't think I'm being "superior", I think I'm putting more thought into this than you are. That's why I've taken the time to respond to your posts in the manner in which I have. I'm not trying to be rude, I'm trying to get you to consider some other angles on the subject of lubricants. We can't just look at one example and say "AH HA! That's proof because of XYZ". There are many different ways to skin a cat. I believe a relatively high VI like that of M1 0w-40 helps make the product a better lubricant. But I also believe that there's a lot more to it than just that. The product performs the way it does because XOM spent an ungodly amount of money developing it to perform that way. We can look at PU 5w-40, their relationship with Ferrari and its use, as well as the fact that there is a tremendous amount of overlap in terms of certs/approvals for both of these oils and see that they are two different ways to do much the same thing. M1 0w-40 has a higher VI. PU 5w-40 has a lower NOACK and better shear stability. Relative performance markers. Both oils are incredible in their own right. Do you see what I'm getting at?
